Which resistor to build 6V photo lithium tester?
Discussion in 'Electronic Basics' started by [email protected], Jan 1, 2005.
  1. Guest
    Hello, and Happy New Year to everybody.
    My battery tester uses a (too weak) 10mA load for its 6V test.
    I'm guessing that a 2CR5 Photo Lithium battery should be tested at
    150mA, under load.
    Any electronics geniuses out there? What type/size resistor should I
    connect to the battery, while testing with my battery meter, to
    simulate a Canon SLR's load, and provide me with an estimation of the
    usability of my 2CR5 (and other 6V lithium) batteries?
    I also have a DMM.
    Thanks for all advise and tips.
  2. Andrew Holme
    Andrew Holme Guest
    Ohm's Law:
    R = V/I = 6V / 150mA = 40 ohms.
    Nearest preferred value = 39
    Power dissipation P = V*I = 6 * .15 = 0.9 watts
    Try a 39 ohm, 1 watt resistor.
