-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Great software for that
Active Ports: readme
Program information
Program Archive Name:
aports.zip
Program Name:
Active Ports
Program Version:
1.4
Program Release Date:
June 19, 2002
Target OS:
Windows NT/2000/XP
Program Description:
Shows all open TCP/IP and UDP ports
Software type:
Freeware
Company information
Company Name:
SmartLine Inc.
Author Name:
Ashot Oganesyan K.
Contact WWW URL:
http://www.ntutility.com
Description
Active Ports - easy to use tool that enables you to monitor all open
TCP/IP
and UDP ports on the local computer. Active Ports maps ports to the
owning
application so you can watch which process has opened which port. It
also
displays a local and remote IP address for each connection and allows
you
to terminate the owning process. Active Ports can help you to detect
trojans
and other malicious programs.
ATTENTION TO DEVELOPERS: if you would like to be able to display
opened
TCP/IP and UDP ports in your application, you can purchase the Active
Ports
programming interface (API). You can use API with any programming
language
(such as Visual C++, Visual Basic, Delphi) that supports DLLs
loading. DLL
contains one function: AllocateAndGetPortsMappingInfo.
To purchase API, please contact Ashot Oganesyan
[email protected]).
License agreement
Active Ports is FREEWARE.
This license agreement is a legal agreement between you (either
an individual or a single entity) and and the author of this
software package.
By installing or otherwise using this software you agree to be
bound by this agreement.
If you do not agree to the terms of this Agreement,
you may not install or use this software.
You may install and use an unlimited number of
copies of this software on your computers.
The author will not make available Technical Support for this
Software. The author may, from time to time, revise or update
the Software. In so doing, the author incurs no obligation to
furnish such revision or updates to you.
THIS SOFTWARE IS DISTRIBUTED "AS IS". NO WARRANTY OF ANY KIND
IS EXPRESSED OR IMPLIED. YOU USE RTM AT YOUR OWN RISK. THE
AUTHOR WILL NOT BE LIABLE FOR DATA LOSS, DAMAGES, LOSS OF
PROFITS OR ANY OTHER KIND OF LOSS WHILE USING OR MISUSING THIS
SOFTWARE.
Installation
Important! If you've got Active Ports not from our web page, but from
the other source (magazine CD or some software library), please visit
our home page - you'll probably find the later version.
To install and use Active Ports you MUST have administrative
privileges.
To install Active Ports you should run the "setup.exe" and follow
the instructions.
Copyright(c) 2001-2002
SmartLine Inc.
All rights
reserved.
Qshiva said:
Dear Group,
I'm looking for a software tool so I can monitor which application
uses which ports on my machine.
Can someone advise me on this ?
Thanks in advance.
Regards,
Shiva
-----BEGIN PGP SIGNATURE-----
Version: PGPfreeware 6.5.8 for non-commercial use <
http://www.pgp.com>
iQA/AwUBP34GGb/hJtP/JADDEQKMyQCghK2jky62hh6VH/g4ikkOOt5CeH0AoLJM
L3pgERG564oRbhm5xeVpocw1
=OPjy
-----END PGP SIGNATURE-----
