James Sweet said:
Well they are *supposed* to work that way afterall, it's just common
to have issues, especially in modern homes with so many sources of
electrical noise as well as filters in power supplies that can
attenuate the signal. The two sides are coupled by the distribution
transformer afterall which in many cases is only a few tens of feet
from the house.
Browsing through the internet I discovered something that indicates that
I don't even need to worry about cross-phase functionality of HomePlug
devices if they are the newer AV 200 Mbps variety. There is this FAQ
item on in the following link:
Question:In my house are three separate phases. Can HomePlug AV 200Mbps
EthernetAdapter connect one phase to another?Answer:Yes, it can. Phase
coupling operates without an installation of a phase coupler whileusing
the HomePlug AV 200Mbps Ethernet Adapter. You also can establish
yournetwork connections via two or three phasesQuestion:In my house are
three separate phases. Can HomePlug AV 200Mbps EthernetAdapter connect
one phase to another?Answer:Yes, it can. Phase coupling operates without
an installation of a phase coupler whileusing the HomePlug AV 200Mbps
Ethernet Adapter. You also can establish yournetwork connections via two
In my house there are three separate phases. Can HomePlug AV 200Mbps
Ethernet Adapter connect one phase to another?
Answer:
Yes, it can. Phase coupling operates without an installation of a phase
coupler while using the HomePlug AV 200Mbps Ethernet Adapter. You also
can establish your network connections via two or three phases.
<ftp://ftp.aztech.com/support/Singapore/HomePlug/HL108E%20HomeplugAV%20Frequently%20Asked%20Questions.pdf>
The following white paper explains the reason:
http://www.atheros.com/pt/plc/downloads/whitepaper_PLCCrossphase.pdf>
What do you think?
When I was a teenager my friend and I discovered that my X10 remote
would operate some of the lights on and in his neighbor's house. We
just clicked the dial through each frequency pressing the all lights
on button until something came on. Poor neighbors finally disconnected
it.
Yes, but X-10 remote controls are radio transmitters, so with the chance
of using the same house code by neighbors, it's relatively easy to
control their lights. X-10 does not use signal encryption.
