Which Microcontroller To Use For A Frequency Counter
radiotek
May 31, 2011
32
May 31, 2011
32
There are so many different type and families of microcontrollers out there it makes it very difficult to decide which one to buy. There are 8 bit, 16 bit and 32 bit controllers and so many different manufacturers making these chips it really makes it confusing which one to use for your project. I will need a microcontroller that will be able to count frequencies to at least 40 Mhz. Any suggestions or help would be appreciated.
Frank
7,682
7,682
I can only speak about PICs. Only the 32-bit PICs would be albe to handle 40MHz directly. To use a smaller PIC you could implement an external prescaler.
radiotek
May 31, 2011
32
May 31, 2011
32
I found a very good website were they are building counters that will measure frequencies uo to 50 Mhz using a PIC 16F628. Maybe I will end up trying this PIC 16F628 if its still available.
http://www.qsl.net/dl4yhf/freq_counter/freq_counter.html
Appreciate your help
7,682
7,682
Hmm. I guess I am wrong then. I looked at several datasheets, but not that one. The others did not indicate a max clock period when using the built in prescaler. This one indicates 10ns of high and 10 ns of low, whcih means it will handle a 50% duty cycle sqauare wave up to 50MHz. If it is not 50% duty cycle it will be out of spec at that frequency.
Harald Kapp
13,700
13,700
Do you nedd to count the 40 MHz directly?
Otherwise you could use an external prescaler as Bob suggested. E.g. divide by 10, and count the resulting 4 MHz signal. Easy for many processors. The resulting accuracy will be the same if you count 10 times longer as you would count a 40 MHz signal - provided the signal has a constant frequency.
