R
Rodo
Hi all...
For a project (primarily in the USA), which frequency would be better to use
433 or 315 MHz ?
I'm looking at the microchip part rfPIC675, which uses either ASK or FSK
The antenna length is the only main difference I know. I don't know much
about RF.
What about FCC approval ? Is one easier to get than the other ?. The project
needs to qualify under FCC part 15. No high speed data transmission needed.
I'll be sending something like temperature info. It will not be periodic.
The info will be sent only when there is a difference of ...say 7.....
degrees.
No need to get too detailed but if you could point me in the right
direction, that's very much appreciated.
433 or 315 MHz ?
about RF.
degrees.
