Which end of the diode is the input?
Discussion in 'General Electronics Discussion' started by Rsmo, Oct 2, 2012.
  1. Rsmo
    Rsmo
    6
    Jul 22, 2011
  2. rawriano
    rawriano
    26
    Oct 2, 2012
    The input side is black, it's the anode.
  3. Rsmo
    Rsmo
    6
    Jul 22, 2011
    Thanks! Is it safe to solder the output ends of 2 diodes together? (and then solder the positive and negative wires leading to a car charger?) The instructions say to do it but I thought I'd ask because it sounds risky to me
  4. rawriano
    rawriano
    26
    Oct 2, 2012
    I'm not sure about that but if out of one output negative will come out and from the other positive that would just simply cause a shortage in the circuit.
  5. davenn
    davenn Moderator
    13,810
    1,944
    yes connecting them the way shown is OK just make sure the diodes you use are rated at 10 Amps else you are going to see smoke from them!!!
    what is the type of diodes you have ? .... part number
  6. Rsmo
    Rsmo
    6
    Jul 22, 2011
