Which diode to use across relay coil contacts
H
Harry Muscle
I'm putting together a circuit that calls for a diode across the relay
coils. However, it doesn't specify which one to use. I'm using a 12V relay
which draws 0.045A (265 ohm coil). Could someone help me out in choosing
the best diode for the job.
Harry
C
CFoley1064
Harry
Generally, the diode specified should be twice the voltage across the relay
when it's on, and a surge current rating at least that of the relay current.
To be conservative, choose a diode with forward current rating at least that of
the relay. That gives you a minimum diode spec of V(r) > 24V, and I(fmax) >
45mA. That would lead you to a 1N914 or 1N4148 as a first choice, but I'm
superstitious and never use those for anything other than reed relays. I'd use
a 1N4001 or 1N4002.
Good luck
Chris
M
Michael A. Terrell
a 1N4001 or 1N4002.
Good luck
Chris
Or go to the 1N4007 diode. its rated at 1000 PIV, and will replace
any of the others in the 1N4001-1N4007 series. It costs the same as the
1N4001, and you only need to stock one part instead of three or four.
2 days!
Michael A. Terrell
Central Florida
C
Chaos Master
In reply to a radio transmission from Harry Muscle(fake@AT) , located at Mars:
Harry
I've used the 1N4007. It's rated at 1000 PIV so it will replace any other in the
1N400x series.
W
Watson A.Name - Watt Sun, Dark Remover
Harry
Use the Harry Muscle kind, a 1N4002 Rectifier.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
