Which Datasheets are best ??
Discussion in 'Electronic Basics' started by Chretien, Mar 31, 2005.
  1. Chretien
    Chretien Guest
    Often when you look up a component you find a site with perhaps 6 or 7
    datasheets on the same component eg Fairchild, NTE, Motorola. etc.. I
    usually Look at one or two take the shortest unless there are examples and
    then download it so I have a copy in future for my hard drive. Some of these
    sheets have all sorts of manufacturing info. You know how many on a reel,
    how far they are spaced apart, real factory info. I avoid those becuase they
    can be 5 or 10 extra pages.
    Because Im a novice I generally can only glean or understand the most basic
    info in these sheets, but force my selt to try to understand them. And
    familierize myself with the terms and layout.
    Anyway, my question is this. Is one manf data sheet better than another for
    me? Instead of reading all 5 or 6 datasheets should i start with one
    manufacturer. Do some of you have preferences and for what reason ?
    What I like is a datasheet that has the BASIC INFORMATION explained in
    relatively SIMPLE TERMS and if possible EXAMPLES. I think everyone must like
    datasheets that have several examples of how to use the components. Do some
    manufactures automaticaly provide this or is it based on (as it seems) their
    wim or perhaps the complexity of the component?
    Regards.
  2. Externet
    Externet Guest
    Hi.
    The best datasheet is the one of the same brand of the chip.
    The best pages are the ones you need.
    The best written is the one you can understand.
    Miguel
  3. [...]
    Not answering your question, but this site has got an awesome collection
    of datasheets:
    http://www.datasheetarchive.com/
    Rikard Bosnjakovic http://bos.hack.org/cv/
    Anyone sending unwanted advertising e-mail to my address will be
    charged $250 for network traffic and computing time. By extracting
    address from this message or its header, you agree to these terms.
  4. You are asking us what datasheet is best for you. You are really the only
    one qualified to answer that question. Use whatever works most effectively
    for you. If simple is what you work best with, then simple ones are what
    you should look for.
    As for me...
    I prefer datasheets that are as complete as possible. This usually means
    whatever datasheet has the most pages is the one I want. If electronics is
    your hobby it is fine and dandy to make something unreliable and spend lots
    of time fiddling around with trial and error trying to fix it/replace
    destroyed components. If you are serious about electronics though, it is
    invaluable to know as much about the components you are using as you can.
    You simply can't make products that are going to be reliable and fully
    functional right from the start on the first iteration unless you fully
    understand your components. The more information the manufacturer provides,
    the more you know about the parts, the more likely you are to obtain good
    success. As it is I pretty much always find myself wishing for even more
    information on the datasheets than is provided. You can never know too much
    about even the simplest of products. Even resistors need datasheets. In my
    experience often the best datasheets for me are the ones produced by the
    industry leaders for that particular product. For instance I consider
    Fairchild and International Rectifier to be the industry leaders in the
    power MOSFET area, and their datasheets also happen to be the best.
    If I were you I would put great effort into learning what all the parameters
    and graphs in the datasheets mean. You will likely find that you are more
    able to make effective products if you learn what every single thing on the
    datasheet means.
