Where to get thermistors in the UK?
Discussion in 'Electronic Components' started by Howard, May 5, 2006.
  1. Howard
    Howard Guest
    I'm looking for an outside temperature sender replacement for a renault
    laguna. (£70 in the spares shop!)
    I understand that I can make one with a 2.7K @ 25 deg beta 3877 thermistor
    such as the Vishay 2322 640 55272 plus a couple of resistors to corect it.
    Unfortunately the only place I can find (Farnells) sells them at £1.32 each
    but with a minimum order of £20. Other places want me to buy 750 of them at
    once. - I only want one (or two so that I have a spare for next time)
    Anyone know where such a thing can be bought over the net in singles or
    where there is a shop near to Huntingdon in Cambridgeshire, UK?
    Howard
  2. Guest
    Sorry I can't help source the thermistor you require. I'm looking to do
    the same as you - make a replacement renault outside temp. sensor.
    Assuming it was possible to find the required thermistor, do you have
    any thoughts on the resistor(s) needed to correct it?
    David
