You could try to make your own electrodes using the snap connectors on a defunct "transistor radio" battery. Just use a pair of diagonal cutters to peel away the soft metal jacket holding the contacts in place. Discard everything else. The contacts should lift right out and you can then use the metal on the bottom as your "sensor" electrode.
Here's a link in case you can't see the image below:
You will want to cut the paper or plastic between the male and female snap contacts so you only have one contact, using the other contact as a removable connector for whatever signal wiring you are using. Of course you will need at least two pair of these to sense any "bioelectrical" signals such as EEG, EKG, EMG, etc. You will also need some electrode paste to apply between the skin and the electrode. Possibly make your own.
Good luck amplifying, filtering, and making sense out of the signals you will see. Skin potentials are fraught with interference from myoelectric potentials, nearby power line wiring, and (probably) the phase of the moon. Isolation amplifiers are mandatory to protect the subject wearing the electrodes from stray currents. Battery operation of electronics is highly recommended.
