B
Bill Kaszeta / Photovoltaic Resources
Depends on your specific application.Greetings,
I am looking a timer where I set the length of time, then push a button and the electric flow for that amount of time and shuts off.
I don't want timers that turn on at a set time and off at a set time. That is out of the question.
I want a timer where you set the length, then push a button. Every time you push the button the timers is set for that length of
time.
W. Kirk Crawford
If you specified operating volts, AC or DC, current, accuracy needed, etc. you might receive a specific answer.
For low accuracy on low voltage DC I use a simple power FET transistor with a capacitor/resistor on the gate, a relay,
and a SPST switch. The resistor can be a variable that you adjust to set the time. If the load is DC and not harmed by
a slow turnoff, the FET can drive it directly. If brewing your own, look at the old LM555 timer circuits for more
accuracy and a definate snap action.
There are 2-inch square timer blocks with a series of small switches to set the time, but they are specific to a voltage
and load current.
Bill Kaszeta
Photovoltaic Resources Int'l
Tempe Arizona USA
[email protected]
