Where to buy Zenith replacement Capacitors?
Discussion in 'Electronic Repair' started by Golf, Sep 25, 2006.
  1. Golf
    Golf Guest
    Trying to locate a supplier for High voltage TV caps. All searches come
    up empty for 560pf/2Kv. Any ideas group? Thanks.
  2. Meat Plow
    Meat Plow Guest
  3. Jim Land
    Jim Land Guest
    You do NOT need to replace the capacitor with a 2kv cap. Just use any
    similar cap with a HIGHER voltage rating. As long as it's 560pf, it will
    work fine. This will give you some options in finding and buying the caps.
  4. Golf
    Golf Guest
    Thanks Jim. Problem is, I can't find the caps with this value and equal
    or higher voltage. I hate to scrap the set due to these caps.
  5. jim menning
    jim menning Guest
  6. Jim Land
    Jim Land Guest
    Search www.mouser.com. They have 560 pf ceramic caps in stock, including
    3kv, 10kv, 12kv, and 15kv.
