Where is the Australian regs/code for users rewiring mains powerplugs??
A
Adrian C
John said:
Since the plug will come straight out of the socket if subjected to a pull
on the flexible cord, how much strain relief do you think it needs?
Enough so that the individual wires don't eventually detach themselves
if the user has a habbit of yanking the plug out like that.
The australian HPM design seems to have included a method to clamp the
sheath (screw up thing at the rear top that radially bites into the
plastic) and three plastic hooks (to wind the individual wires about to
reduce movement near the screw terminals).
F
F Murtz
There is no explanation needed,it should be evident, the hooks and
compression nut should tell you something.
