where does this go?
Discussion in 'Electronic Repair' started by bigtom, Jan 26, 2005.
  1. bigtom
    bigtom Guest
  2. Techforce
    Techforce Guest
    looks like a slide plate for the mechanism. I have also seen 'extra parts'
    jammed in mechanisms causing them not to work - something that happens on
    the production line from time to time. If it works without it, then probably
    that extra piece was causing a problem, and perhaps led to belt failure.
    |i replaced the belts on a pioneer KE-8000 car stereo.
    | after putting it all together i had a piece left over.
    | what is this thing and where does it go?
    | it all works ok without it but it would be nice to put it back in.
    | http://community.webshots.com/photo/260167015/260167266AOYBuW
  3. jakdedert
    jakdedert Guest
    Dude! He's pulling your....
    jak
  4. Harvey
    Harvey Guest
    That looks to me like the cassette mechanism - in which case there should be
    a large hole in the radio that it fits into.
  5. jakdedert
    jakdedert Guest
    Duh! It was a joke. Did nobody else get it?
    jak
  6. What do you expect from a hotmail.com
  7. bigtom
    bigtom Guest
    Its not a joke.
    The hotmail acct is never used, i just use that address to avoid spam.
    I really can't find where this thing goes.
    Any help would be appreciated.
  8. bigtom
    bigtom Guest
    I read through the posts again and it seems some people are confused
    about the photo.
    The part im trying to fit is the little steel thing at the bottom of
    The photo.(look carefully)
    P.S. The belts were stretched(old age/heat)
  9. worldcitizen
    worldcitizen Guest
    If it is made of thin plastic, then it is probably an insulator that
    goes between a circuit board and a metal part like the chassis.
  10. Doug
    Doug Guest
    Wow, that's old! I looked in the Pioneer service manual, and I can't
    find it even in the exploded view. It may have come from an assembly
    that's not shown as separate parts, but I doubt any of those would have
    been disturbed during a belt replacement. We had boxes of those
    mechanisms in our skull orchard but chucked them a few months ago,
    running out of space. Wish I still had one or two to look at. Good luck!
  11. So we are supposed to know that, be more explicit .
    kip
  12. Graham
    Graham Guest
    Graham.
    %Profound_observation%
    Yes I know what this is
    Its an old cassette deck, if I were you I wouldn't bother putting it back,
    it has long been superseded by more modern digital formats such as the
    Compact Disk
    The cassette or rather the "Compact Cassette®" was invented by the Dutch
    company Philips in the early 60's. Originally intended for voice recording
    and therefore designed with no regard for sound quality it nevertheless
    quickly gained acceptance with hobby recordists
    Interestingly the humble cassette has gained more from the technical
    advancement of the last 20 years than any other analogue medium, some 10
    years ago I was by no means ready to accept the budget cassette recorder as
    a hi-fi medium and considered the format to be a convenience format since it
    was the only format you could count on being playable in every household.
    But the performance of even budget dual decks that sell locally for under
    100 UKP (around 130 USD or ?) is nothing short of stunning, at the very
    least if you compare it with what they where a few years back. Since getting
    a decent cassette recorder the Compact Disk Recordable unit has been
    relegated to making archival copies of CD's only. The user friendliness,
    generality and reliability of the cassette makes the more modern format seem
    somehow awkward and time consuming.
    There are some technical descriptions in the text that have been making
    problems for some of you out there so I will give a short explanation of a
    few here. Bidirectional means that the deck can record on all tracks at
    once, thus cutting the recording time in half if you are copying cassettes,
    this has no effect on other recordings.
    Graham.
