Where can I find a 60pin 1.27mm connector???
Discussion in 'Electronic Design' started by Edu, Oct 14, 2006.
  1. Edu
    Edu Guest
    Hello.
    I have just bought a GSM oem module, and am having lots of trouble to
    find the connector for this module.
    It should be a 60 pin (in 2x30), for flat cable, like the ones in IDE
    drives, but with a spacing (both between pins and rows) of 1.27mm
    (0.05") , instead of 2.54mm (0.1 ").
    For the moment I have not had any luck. At first I will need only 2
    connectors to develop my prototype, but surely in short I will be
    buying lots.
    Any help?
    Thanks!
    Edu
  2. Robert Baer
    Robert Baer Guest
    See DigiKey pages 61-62, 67-70, 86, 166-170, 329 (verified, as
    sometimes listing in product index is incorrect).
    Am sure Mouser also carries same lines.
  3. Edu
    Edu Guest
    Thanks for all those references, but I haven't found what I need in
    them.
    Is there any way I can query someone in digikey with my description of
    the product?
    What does people who buy a Sony-Ericsson GSM GR47 module do with the
    connector??? Where do they get it???
    Thanks!
    Edu
    Robert Baer ha escrito:
  4. Donald
    Donald Guest
    You are making your search too complicated.
    Looking at the pictures of the module at:
    http://www.sonyericsson.com/spg.jsp?cc=us&lc=en&ver=4002&template=pp1_1&zone=pp&lm=pp1&pid=10086
    Its just a dual-row connector.
    Looking at other products that use this module shows just a dual-row
    connector.
    http://www.google.com/search?hl=en&lr=&c2coff=1&q=Sony-Ericsson+GSM+GR47+connector
    Good Luck
    donald
  5. linnix
    linnix Guest
    You put the male connector on a Flexible Circuit board.
    It comes in 80 pins right angle surface mounted dual row 0.05" pitch.
    I got a few pins sample left (4 pins). Minimum order is 1,000 @ 50
    cents each.
