Wheelchair motor
Discussion in 'Sensors and Actuators' started by Frank3point14, Sep 15, 2013.
  1. Frank3point14
    Frank3point14
    10
    Sep 6, 2013
    Hello..!!!!
    I am Electronic Hobbyist...
    I'm working on Electric Wheel Chair.....
    I'm confused about Motor(Which DC/AC motor should i choose) and as i want to implement it with cost efficiently is there any idea about low cost Joy stick..
    Thank YOU !!!!!
  2. conductor3
    conductor3
    84
    Jun 7, 2011
  3. conductor3
    conductor3
    84
    Jun 7, 2011
    unless you need digital
  4. Frank3point14
    Frank3point14
    10
    Sep 6, 2013
    Actually it's great....
    Thanks a lot......:)
  5. Frank3point14
    Frank3point14
    10
    Sep 6, 2013
    I 've a question that is this joystick is compatible to PIC18FXXXX......????
    CUZ i want to use PIC..!!!!
    Is this possible....!!!!Any idea...
  6. conductor3
    conductor3
    84
    Jun 7, 2011
    the only thing i can tell you is that the on i showed you has 5 pins (VCC, GND, X, Y and sw) vcc goes to positive and gnd goes to negative x,and y are anolog outputs for the x and y axis and sw is a digital out for the push button the two pis on the board labled r5 is for a resistor (pull down) but they dont come with it so you need to add one if your going to us it (it will ruin a microcontroller if not put there)
  7. conductor3
    conductor3
    84
    Jun 7, 2011
    so all you need is a microcontroller with positve and negative and 2 anolog inputs toread a variable between positive and negetive (there is 2 potentiometers on it onefor each axis)
  8. Frank3point14
    Frank3point14
    10
    Sep 6, 2013
    Thank you.....:)
  9. conductor3
    conductor3
    84
    Jun 7, 2011
    heres a quick diagram
  10. conductor3
    conductor3
    84
    Jun 7, 2011
    and the moter will be dc other wise you wont be able to go backwards
  11. conductor3
    conductor3
    84
    Jun 7, 2011
    if your pic has 2 analog inputs it will work
  12. Frank3point14
    Frank3point14
    10
    Sep 6, 2013
    That's really helpful.....
  13. conductor3
    conductor3
    84
    Jun 7, 2011
    any thing else just private mesage me
Similar Threads
Loading...
