What's wrong with this code? (PIC 16F528A)
Discussion in 'Microcontrollers, Programming and IoT' started by grkmr, May 21, 2011.
  1. grkmr
    grkmr
    13
    Jan 31, 2011
    I want to compare two voltages and sound the buzzer if referance voltage is higher than the other. However, when I change the voltage values on corresponding pins, nothing changes at the buzzer pin (it always sounds or nothing happens). As I investigate some example codes on the internet I saw that I should use some commands like ADRESH or ADRESL to compare the converted values by the internal ADC of the PIC I'm using. However I dunno how to modify my code. I think there's a problem with "IF PORTA.3 > PORTA.0 THEN..." part of my code. I think I can not compare the pins directly but I should compare the converted binary values. I dunno how to do it exactly. Another problem might be activating the corresponding pins AN0 and AN1. Could you please help me? Here is my code:
    '* Name : UNTITLED.BAS *
    '* Author : [select VIEW...EDITOR OPTIONS] *
    '* Notice : Copyright (c) 2011 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 18.05.2011 *
    '* Version : 1.0 *
    '* Notes : *
    @ DEVICE pic16F628a
    @ DEVICE pic16F628a, WDT_on
    @ DEVICE pic16F628a, PWRT_ON
    @ DEVICE pic16F628a, PROTECT_OFF
    @ DEVICE pic16F628a, MCLR_OFF
    @ DEVICE pic16F628a, INTRC_OSC_NOCLKOUT
    CMCON=7 ; Turn OFF the comparators, and use these pins as normal
    ; digital I/O-pins
    VRCON.7=0 ; Disable voltage reference module
    TRISA = %01111111
    CMCON = %00000010
    T1CON = %00000001 ; Enable Timer1 with a prescaler of 1:1(1microsec.)
    PIE1.0=1 ; Enable Timer1 as peripheral interrupt source
    PIR1.0=0 ; Clear Timer1 interrupt flag
    INTCON =0 ; All interrupt are disable
    BUZZER VAR PORTA.7
    MAIN:
    while 1=1
    HIGH BUZZER
    else
    low buzzer
    endIF
    wend
  2. (*steve*)
    25,359
    2,755
    You will need to use the ADC on those pins to determine a numerical value associates with the voltage on them. These values can be compared.
  3. grkmr
    grkmr
    13
    Jan 31, 2011
    I know I should use ADC but in our PIC, we have an internal ADC. However, I am wondering how to activate this corresponding pins and how to compare by using code?
  4. (*steve*)
    25,359
    2,755
    I am sure the documentation for your compiler will tell you how to use the ADCs.
    What is the compiler? Maybe I can google it for you :(
  5. Digital_Angel_316
    Digital_Angel_316
    41
    Oct 1, 2011
    The code segment below is from a Microchip AppNote. The key is to set up your I/O first, then to enable and initiate the A/D function. Take a look at the code and see if it makes sense. The AppNote might be a useful read over lunch. BTW I do not see the particular part you are mentioning, is there a typo in the OP?
    APP NOTE:
    Four-Channel Digital Voltmeter with Display and Keyboard
    http://ww1.microchip.com/downloads/en/AppNotes/00557d.pdf
    AdDone
    btfsc ADCON0, GO ;ad done?
    goto AdDone ;no then loop
    bsf ADFlag, ADOver ;set a/d over flag
    call RestorePorts ;restore ports
    return
    DoAd
    clrf PORTB ;turn off leds
    bsf STATUS, RP0 ;select Bank1
    movlw 0x0f ;make port a hi-Z
    movwf TRISA ; /
    bcf STATUS, RP0 ;select Bank0
    bsf ADCON0, ADON ;start a/d
    movlw .125
    call Wait
    bsf ADCON0, GO ;start conversion
    return
    Wait
    movwf TempC ;store in temp
    Next
    decfsz TempC, F
    goto Next
    return
