what's wrong with this circuit?
B
budgie
http://members.ozemail.com.au/~pebarhug/radios/2N3055schem.jpg
A fellow hobbyist told me it was not a good circuit arrangement as it had
poor regulation with the NPN pass transistors. Can someone explain to me
why?
He's right, it's not a good circuit. The current-sharing emitter resistors will
degrade the regulation. The regulated point is their base junctions.
3-terminal regs have an internal feedback ararngement that regulates their
output pin voltage, meaning anything after that is effectively unregulated.
As a further point, look up the hFE of a 2N3055. It seriously sucks as the
collector current rises. Three x 2N3055 at 20 A is gonna take a LOT more drive
than a (non-moose) 7805 will provide.
P
Peter
resistors will
unregulated.
the
drive
max hFE of 2N3055=20
non-moose?
A
Arfa Daily
resistors will
unregulated.
the
drive
I agree with all that Budgie has said, in principle. However, it might be a
case of horses for courses. As to whether the circuit is any good, will
depend on how critical of voltage sag the circuit that you are using it to
drive is. The three 0.22R current sharers in the emitters add up to a total
of about 0.07R, so at 10A drain, you are looking at a voltage drop of about
0.7 volts across them, which may not be any great shakes for the driven
circuit. However, as Budgie says, the transistors themselves may well be the
limiting factor as to usefulness in this regard, because the voltage drop
across them will increase substantially as the current drawn increases, due
to their poor high current gain. Again, this is not a great problem if you
are looking at a steady current requirement by the load - you just turn the
sucker up a bit to maintain the output voltage that you need. Problems start
when the load is dynamic.
An LM317K would be the choice for the adjustable regulator, as this would
be able to supply the drive current needed. I would treat the circuit as
maybe a useful primer to build if you're just getting into this sort of
thing. It would be a good basis to play with, and to illustrate the
principles involved, and you might even be able to modify it to employ some
output feedback
Arfa
S
Sam Goldwasser
output feedback
This is similar to the circuit in the Texas Instruments LM317
datasheet. Although not specified, I expect this is good for up to 5 A
or more depending on the actual voltage difference between input and
output and the size of the heat sink used for the power transistor, Q2.
+-------------------.C E.-------+
| Q2 _\___/_ |
| 2N3055 | |
| (NPN) | |
| | R5 |
+---------.E C.------+---/\/\---+
| Q1 _\___/_ 500 |
| 2N2905 | |
| (PNP) / R4 |
| \ 5K |
| R3 | I +-------+ O | 1N4002
Vin (+) o---+-+---/\/\---+---| LM317 |---+----+--+------+-------+---o Vout (+)
| 22 +-------+ | | | |
| | A / _|_ | |
| | \ R1 /_\ D1 | |
| | / 120 | | |
_|_ C1 | | | +_|_ C2 /
--- 10uF +-------+---+---+ --- 47uF \ RL*
| \ R2 +_|_ C3 | |
| +->/ 5K --- 10uF | |
Vin(-) o------+---------------+--+-----------+----------+-------+---o Vout (-)
Since the regulation point is at the emitter of the 2N3055, it will have
the stability of the LM317. Multiple pass transistors can be paralleled
with small emitter resistors for current equilization without sacrificing
regulation. Or, MOSFETs can replace the 2N3055(s) without worrying about
equilization.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
B
budgie
Forget hFEmax. Look up the hFE at 5 or 7A, and you need to design on the worst
case (min) figure at Icmax.
non-moose?
There was a 5A variant of the 78xx regulators, and it was named "Moose" by IIRC
National. But do the sums at 20A and see how much base current those critters
want. They may be ubiquitous but that doesn't make them a good choice. There
are far better bipolars for this type of application.
Jeff Liebermann
why?
Argh. That's an awful design. The lack of voltage ratings on the
output, xformer, and cazapitors should be a clue.
1. The output voltage isn't regulated. The feedback stops at the
base of the 2N3055 xsistors. The regulation is further mangled by
having 3ea 22 ohm resistors in series with the output. The voltage
drop across these resistors will vary with the load current, which is
not exactly my idea of voltage regulation. Ummm, doing the math:
E = I * R = 5A * 7 ohms = 35 volts
The 7 ohms is from 3ea 22 ohms effectively in parallel. In order for
this piece of junk to output any voltage at 5A, the regulator input
voltage will need to be 35 volts plus the regulators dropout voltage
and Veb. It won't at all work with the 22 ohm resistors.
2. In normal operation, the 22 ohm resistors will cook. For example,
if this power supply really does mangage to output 5A then the
dissipation in the resistors will be:
P = I^2 * R = 5^2 * 7 = 175 watts.
Not even close.
3. The output isn't current limited or protected. Short the output
to ground and you get 1A (output current limit of the 7805) through
the base-emitter junction of the 2N3055. The usual value for such
emitter follower load equalizing resistors is prehaps 0.22 ohms. Were
those used in this design, the current would smoke the EB junction on
of the 2n3055's.
4. The diodes listed are all plastic parts that will get rather hot
near their current limits. For anything over about 8 Amps, one really
should use diodes with heat sinks.
5. Using a full wave center tap xformer means that the xformer will
be twice as large as a smaller xformer with a diode bridge.
Start over.
P
Peter
Not even close.
of the 2n3055's.
Start over.
Jeff Liebermann [email protected]-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann AE6KS 831-336-2558
Many thanks, guys for all the responses. They've helped clarify my
thinking.
Peter
A
Arfa Daily
Not even close.
of the 2n3055's.
Start over.
There is a decimal point on the schematic. That's zero point two two ohms.
That makes the Rt 0.07R. That makes the voltage drop across them, at 5 amps,
0.35v , not 35v ... How do you arrive at a maximum output of 1A ? Whilst the
7805 can deliver a maximum output of 1 amp, this figure is multiplied by the
current gain of the 2N3055's. Assuming a ( poor ) gain of 20 on them, that
would result in an output current of some 20 amps with 1 amp of drive to
their bases. That is the whole point of having external series pass
transistors. The output current is drawn from the collector-emitter circuit,
not the base-emitter circuit, so there is no reason why the base-emitter
junctions should fry.
The output is current limited and protected by the fuse feeding the series
pass transistors' collectors.Admittedly, this is not very elegant, but it is
protection, no matter which way you look at it.
It doesn't make any difference to the size of the transformer, if you have
one 20v 20A winding, or two 20v 10A windings, series'd and grounded at the
junction. It's still 400vA either way
I agree that this is not a *good* design, and will suffer from poor dynamic
regulation due to the current-dependant drop across the current sharing
resistors, but it is at least functional, and a simple useable design to
produce an adjustable, reasonably high current output. Depending on what it
is needed for, it might be quite adequate, and its shortcomings, of little
or no consequence.
Arfa
Jeff Liebermann
0.35v , not 35v ...
I'll take your word for it that there's a decimal point. It looks
more like a blur or a smear to me. In the USA, the decimal point goes
at the base line of the lettering. Other countries have it in
different places. I guess this one is in the middle. Anyway, as I
indicated in my analysis, 0.22 ohms is a more reasonable value.
The 1A was my guess as to the short circuit output current with the
fuse blown. Short the output to ground with the fuse blown and the
current gain doesn't even enter into the picture. 100% of everything
the 7805 can deliver will go through the base-emitter junction.
With the fuse not blown, the output current will go to whatever the
xformer and diodes output, minus 0.6V for emitter-base, and whatever
drop is across the 0.22 ohm resistors. That should blow the fuse,
followed by blowing the emitter-base junction.
Of course, the 7805 has current foldback, which will limit the amount
of current that it can supply to safely reduce dissipation. It may
take a while to blow up. Meanwhile, it will probably oscillate
merrily.
Not if blowing the fuse also causes the emitter-base junction to blow
up from excessive current. I could supply a better analysis if I knew
the values of the xformer voltage and current and what value of fuse
is specified.
Interestingly, the range of output voltage is rather odd. Using the
7805 example, the 270 ohm resistor and 5K pot form a divider with:
5V * 5000 / (270 * 5000) = 4.74 V
Therefore, the maximum output voltage is 9.74 V (minus the Veb drop in
the 2N3055. I'll call it 11 volts maximum output. The range of
output voltages is 4.4V to approx 11V.
At full current (5A), the three 0.22 ohm resistors appear as a single
0.7 ohm resistor for a drop of 1.1 volts. Therefore, the output
voltage will vary over a range of 0 to 1.1 volts depending on the load
current. This is not what I would call good regulation. It's 4 times
worse at 20Amps.
The 7805 is not an LDO regulator, so we'll need a few volts drop
across it. My guess is about 5 more volts. Therefore, the xformer
and full wave center tapped bridge need to supply 32V center tapped at
5Amps. That's a fairly large xformer. At 20Amps, it's a fairly huge
transformer.
With full wave center tapped, you're only using one half of the
xformer secondary at a time. Therefore, each *HALF* of the secondary
has to supply the full current and full voltage for half a cycle. Half
a cycle later, the other half of the xformer is doing the work, while
the first half just sits there. To supply my calculated 16 volts of
DC from the full wave center tapped system, each *HALF* of the
secondary would have to supply 16VAC at 5Amps for a rating of 32VAC CT
at 5Amps.
To do the same thing with a full wave center tapped arrangement, the
entire secondary is used each half cycle. Therefore the xformer
rating would be 16VAC at 5A or half the size. Ignoring slight
efficiency differences, and a larger physical size, the xformer rating
for both devices would be about 80VA, but the center tapped version
would be about twice as physically large due to the doubling of the
secondary windings.
One more. At 20Amps, 4700uF is inadequate filtering. I'm too lazy to
do the numbers. It needs a series resistor or choke.
or no consequence.
I beg to differ with you conclusions. The design is unsafe, has no
short circuit protection, may oscillate, uses an inefficient xformer
design, has improperly selected diodes, has miserable voltage
regulation, and will blow up the 2n3055's if the fuse is removed or
blown. Since the application has not been specified, neither you nor
I can judge if the design is adequate.
P
Peter
merrily.
is specified.
worse at 20Amps.
transformer.
at 5Amps.
secondary windings.
Apologies if the schematic was not clear - on the original it's .22 ohms
ie 0.22 Ohms
F
Franc Zabkar
why?
TIA
Peter
Remembering that this is a variable power supply, ie one where the
voltage is trimmed to suit the load, and assuming that the load is
reasonably constant (eg 10 +/- 1 amps), then the regulation error in
this case would be +/- 70mV. This is not too bad at 13.8V, say. OTOH,
a bursty load such as amateur radio equipment will be poorly
regulated. Having said that, I doubt that this would matter much to
most radio hams. In fact a friend had a simple design based on the
same pass transistors and an LM723 regulator IC. The transformer was
massive, though.
- Franc Zabkar
Jeff Liebermann
Oops. I added instead of subtracted. That's what happens when I try
to eat dinner in front of the computer. It should read:
the 2N3055. I'll call it 9 volts maximum output. The range of
output voltages is 4.4V to approx 9V.
A
Arfa Daily
*** That's interesting that you only see the decimal point as a blur. Are
you by any chance using an LCD monitor in non-native resolution ? I say this
because the point is perfectly sharp on my CRT monitor, and there has been
quite a debate going on here from time to time about the relative merits of
CRT over LCD when it comes to fine detail, and photographic colour
rendition. Over here, the decimal point went in the centre when I was a kid,
but by the time I was at senior school, it had been moved to the bottom.
This is one reason that we were always taught to preceed any such value with
a zero. Over here now, the decimal point tends to be omitted so as not to
cause confusion with spots of fly-crap on the page. Thus, a 0.22ohm
resistor, would be written as 0R22 or just R22. 22 ohms would be written as
22R. Likewise caps - 4.7uF = 4u7 6.8nF = 6n8. A better form of
nomenclature, I think.
*** Ah, OK ! I see where you're coming from now. Valid point - in theory.
However, my data shows a max base current for the device of 7 amps. Bear in
mind also, that as long as the current sharing resistors have not gone open,
any short circuit current drawn, will be spread among the three 2N3055s. As
the 7805 can only supply a maximum of around an amp before going into
overcurrent foldback, this will be only represent around 330mA per
transistor base. They should be able to handle this all day, without so much
as a whimper, let alone a grunt. So yes, I agree that the circuit may well
produce around an amp of short circuit current, but I do not agree that this
will blow out the 2N3055s' B-E junctions.
merrily.
*** There is probably just about enough decoupling around to stop it
oscillating under fault conditions, but had it have been my design, I agree
that I would probably have put a bit more in. The regulator, properly
heatsunk, should be able to cope with overcurrent foldback, which keeps the
device within its SOA, all day.
is specified.
*** I don't believe that the B-E junctions will blow - see above
*** The use of a 7805 nominally fixed regulator is, I agree, an odd choice.
I would not recommend attempting to use one of these in a variable
configuration. However, the alternative LM317 specified is, AIR, a genuine
adjustable regulator, which goes down to its internal reference voltage of
1.2v, and up to around 35v, so by the time you had factored in drops in the
series pass element, you would get down to nearly zero output, and up to
somewhere near what you were putting in.
worse at 20Amps.
*** Slight error in the math there ! 3 x 0.22 in parallel, is 0.07 ohms,
not 0.7 ohms, thus at 5 amps, the drop across them is 0.35v, and about 1.4v
at 20 amps
transformer.
at 5Amps.
secondary windings.
*** Yep, I'll conceed that one !! Your thinking is much clearer than mine.
In mitigation, I'll just say that it was in the very early hours that I was
sitting here thinking about it ... !! ( but still no excuse ... )
*** That may or may not be true, depending on the application. Many loads
will not mind a dirty output. I agree that if it were my design, I would
probably put better filtering in, with larger caps, but there will be a
degree of electronic smoothing achieved, even with this poor design, by the
basic 78xx or LM317 regulator element. AIR, these devices exhibit around
70dB of ripple rejection. However, I wouldn't suggest that this circuit
would achieve anything like that figure, because any good regulation or
ripple rejection at the bases of the series pass elements, will be worsened
by a factor of their gain.
*** I don't really think that the design is fundamentally unsafe per se,
and I reject your contention that the design has no short circuit
protection - see above. It may oscillate under the right ( wrong ?? )
conditions, but I think that this is fairly unlikely, given that there are
decouplers in the right places. I agree with your analysis of the diode and
transformer specifications. I agree that the potential voltage regulation is
poor compared to some other designs, but not necessarily, that it falls into
the "miserable" category for low to medium demands. I dispute that it will
blow the 2N3055s if the fuse fails or is removed - see above. I agree that
we cannot judge the design in terms of specifics, without knowing the
ultimate requirements of it, nor was I trying to, but that does not preclude
judging its validity as a standalone circuit, suitable and adequate for
*some* applications. Actually, if you think of it more as what it is - a
variable voltage source - rather than what it's not - a properly regulated
power supply, then it has many valid applications supplying non-critical
loads. A few that spring immediately to mind are minidrill speed controller,
model railway speed controller, sump pump speed controller, garden pond pump
speed controller, low voltage lighting intensity controller, gel battery
charger and so on.
Arfa
Jeff Liebermann
"Arfa Daily" <[email protected]> hath wroth:
Dell P1110 19" viewable flat screen CRT. I can't afford an LCD
monitor at this time.
I say this
rendition.
I'm familiar with the merits of this discussion. I usually recommend
that customer purchase 1600x1200 LCD displays so that running the
display had 800x600 does not result in a pixel roundoff error.
Agreed. That was my problem. In the USA, the decimal point is always
near the bottom of the line. I thought the spot was a smear. Please
note that literally *ALL* my previous posting have the leading zero to
avoid confusion. 0.22 or 0R22 would be fine. R22 is not because it
is easily confused by the resitors reference designator. If the
common usage has been anything other than the letter "R", I would also
do it this way, but I've had far too much trouble with mixing values
and reference designators on schematics than losing a decimal point.
The capacitor examples might work as it's unlikely to confuse U47 (an
integrated circuit) with 4U7, a cazapitor. I've done it many
different ways, as demanded by various companies drafting standards.
http://www.onsemi.com/pub/Collateral/2N3055-D.PDF
Y'er correct. I should have looked at the data sheet first. I didn't
realize that the 2n3055 can handle 7A of base-emitter current. 333mA
is not going to blow up the 2N3055's. However, I find it a rather bad
design that can blow the fuse, and still produce substantial output
current.
I've dealt with my share of 3 terminal regulators in various designs.
Depending on the construction, load impedance, lead lengths, etc, I
can sometimes make them oscillate. 1uF is not enough. I usually use
0.1uF in parallel with 10uF.
I agree. It will not blow up.
Agreed. LM317 would be a better choice. It will go down to
approximately 0 volts.
http://www.national.com/ds/LM/LM317.pdf
at 20 amps
Oops. I hate it when that happens. That's not as horrible regulation
as I miscalculated. However, it's still not as good as it might be if
the 2N3055's had been inside the feedback loop.
Well, I made more mistakes than you have. My excuse is that I was
constantly getting interrupted while writing my reply and didn't have
time to do much more than a spelling check.
The LM317 will certainly help with the ripple reduction. However, the
ripple will appear at the collectors of the 2n3055's which does not
have as much ripple rejection as the LM317. The ripple won't be huge,
but it will be present.
It's a bit more important than just minimizing the ripple. There's
the problem of ripple current. The input filter capacitor conducts
lots of current on each half cycle. I once repaired an Astron 60A
linear DC power supply. The problem was that running at almost full
load, the single 250,000uF 25VDC (not sure of values) had a
sufficiently high ESR that the screw terminals literally melted on the
capacitor. At 5A to 20A, this is not a problem. However, even at
20A, the 4700 uF capacitor might get hot. The LM317 will clean up any
ripple that's left, but the cazapitor still has to supply the power
between cycle peaks.
I do. Any circuit that continues to supply power after the fuse
blows, and that does not have short circuit protection, is in IMHO
unsafe.
Ok. Turn the LM317 version to full output at perhaps 25VDC. Now,
short the output to ground. Will the fuse blow? Maybe depending on
the value selected and whether the xformer can supply the necessary
power. The fuse really belongs in series with the output voltage (as
well as adding a fuse on the 117VAC input). When the current goes to
the limit, it is sure to blow because the 2n3055's will supply the
necessary power to blow the fuse. It's not so clear whether the fuse
as shown will blow. If the LM317 goes into current foldback
protection mode, it won't blow. The output voltage will also drop to
about Vbe plus whatever the LM317 outputs. However, put a big filter
capacitor load on this thing, and it will take time for the LM317 to
complain. There's probably enough power left during this time to blow
the fuse. I can't really tell without values or bench testing (or
modeling). I guess you could call this load dependent protection.
I can make it oscillate with an inductive load. The 1uf is strictly
for improved transcient response, not filtering or stability.
Agreed. It's not as horrible as I thought. It's still quite bad and
could have been done much better.
Agreed. The 7A of base-emitter current is sufficient to prevent
destruction. I assumed a much lower value.
charger and so on.
All of these will function except the gel cell battery charger.
Charging a gel cell battery is not a trivial exercise and should not
be done with an ordinary power supply. Go over voltage for just a
small amount of time, and the battery is toast. The other
applications are not particularly critical and can probably tolerate
such a power source.
What the hell are you all talking about ? Using a linear regulator is
nuts, even for a mildly competent amatuer.
Get yourself a coil and design a slicer circuit. If you like American
transistors get your hands on a 2N3773 and throw those 3055s out. We
don't have any aluminum trees here anymore. We can't just go out and
pick heatsinks in the backyard.
If nobody in here can design a chopper circuit, I will do it. I won't
even use pi, in fact I think I can do it without a calculator, but
don't hold my feet to the fire on that particular issue.
Chopper circuits are the bomb, they can actually put out more current
than they drain. Linear regulators are a thing of the past. Of course I
know that manufacturers still use 78XX series regulators in products,
but there is a different reason for subregulating a supply. That is a
different subject.
If you don't want to design use a upc494 and put your "fingers" in the
feedbacvk loop. It can automatically give you max on times etc, and
IIRC current limiting, but you could design that with any chip, once
into the feedback loop. I think you don't even need a chip, unless
maybe an OPAMP or comparator.
Here's cheap and dirty, let the circuit you have oscillate, put a coil
in the collector of the final outputs. Let it settle on any frequency
it likes. Add one coil and remove most of the capacitors is all that's
needed. If it runs hot get a final with more gain. Even to do this
though you wil need to modify the circuit going to the base. Just
assure it turns on and off quickly and completely.
I'll get my pencil out later.
JURB
