Anonymous said:
We use a fair amount of batteries, mostly aa and aaa, to power various
gadgets. ....
Any recommendations?
Use NiMh. But it matter both what you are using them for/in, what
charger you use, and how well you maintain things.
If you believe in memory effect, please go flush your brain until you
don't, or until you only believe that it applies to specific situations
run into on satellites with NiCd - and you're being told to get NiMh.
Running rechargables "totally flat" is bad, leaving them flat is worse
(if you must run them "out", then recharge immediately). Recharge early
and often is the current conventional wisdom.
If not using them for a month or more, recharge them every month, or
you'd have been better off with non-rechargeables.
Putting it in a long-term low-draw item like a clock - buy a
non-rechargeable.
Charger - I like a "smart" one - present version I have will charge 1-4
cells to 80% in 15 minutes - has temperature sensing, a fan, charges in
pulse mode, doesn't fry batteries that are left in it for days or weeks.
Could be a bit better in that it does not have a definitive indication
when it's done with the last of trickle charging, but it does what I
want one to do, having had poor experiences with trickle-charging
versions.
Sets. Mark batteries to maintain "sets" to fit your appliances, and
keep/use/charge each set together.
Shop carefully - you can easily pay 3-4X the price for exactly the same
thing by shopping carelessly, or you can be mislead by something
described as a "rapid" charger which defines "rapid" as "8 hours"
somewhere in the fine print. Look for larger packages of batteries,
which might be cheaper per battery - 20 packs, for instance.
Works for me. I've been feeding them to the heavy-draw AA stuff around
here and it's been working fine for several months - no way to tell how
it will be in the longer long term, but it's already cheaper than
disposables would have been (mostly because those cost so much).
