What's the UK telephone connector called?
Discussion in 'Electronic Design' started by Dr. O, Nov 27, 2003.
  1. Dr. O
    Dr. O Guest
    Does anyone know the technical name for a UK telephone connector (female)? I
    want to order one from a manufacturer.
    Thanks in advance!
  2. Sprow
    Sprow Guest
    You wont be able to order one unless you know what you're after,since
    the part number changes depending on the style - even the male
    connectors are available with the locking spring on the left or right.
    For example,a straight PCB mount through hole connector is BT Type
    605A whereas the right angle one is BT Type 603A,
    Sprow.
  3. cpemma
    cpemma Guest
    Do you mean wall, line or back-box mounting? The back-box design comes in
    master or secondary, then IDC or Screw connect. Others secondary only.
    BT code LU2/3A (IDC) or LU2/6A (Screw) are 68mm square face-plate secondary
    types "Line jack unit 2" sold everywhere for DIY extensions.
  4. cpemma
    cpemma Guest
  5. Dr. O
    Dr. O Guest
    Uh no. I need some PCB mountable UK telephone connectors, preferable SMD.
  6. Farnell and RS stock them. BT types 603A and 605A, for example. Not SMD.
