What's the minimum refresh clock for SDRAM.
Discussion in 'Electronic Design' started by Boki, Oct 27, 2005.
  1. Boki
    Boki Guest
    Hi All,
    What's the minimum refresh clock for SDRAM, I knew it depends on
    ram cell, but could you provide a reference? thank you very much.
    How about .25um process / 70ns speed.
    Best reagrds,
    Boki.
  2. Tim Wescott
    Tim Wescott Guest
    The best way to answer this would be to look at a data sheet. If you
    want a general answer look at a bunch of data sheets. If you want a
    theoretical answer then I can't help, but I suspect it would be "how
    long do you want?"
  3. Boki
    Boki Guest
    as low as possible, because it save power, isn't it ?
    Best regards,
    Boki.
  4. Spajky
    Spajky Guest
    in my first PC I had 66MHz PC66 sticks , Bios timings 60ns; I used
    the largest possible interval = 256us ... no crashes & faster
    performance ...
  5. Boki
    Boki Guest
    Why possible faster?
  6. Spajky
    Spajky Guest
    because when cells are read & refreshed with refreshing clock
    impulses, that time are not accessible for write/read operations for
    other stuff, thus less refreshing, better real life Ram performance;
    the differences can be up to few % ...
  7. Rich Grise
    Rich Grise Guest
    A longer interval means a less-often refresh cycle, stealing fewer cycles
    from the processor, albeit I find it a little hard to believe that the
    difference in performance would be _that_ noticeable. :)
    Cheers!
    Rich
  8. Boki
    Boki Guest
    lower refresh cycle doesn't mean lower processor load.
    I can't understand this yet.
    Best regards,
    Boki.
  9. mike
    mike Guest
    The minimum refresh rate is specified in the data sheet.
    If you do it less often, you build in intermittent loss of data.
    The only way to get reliability at lower refresh rates is to
    have the vendor select parts to YOUR custom specification.
    Quick step up to the soapbox...
    It's hard enough to make a reliable system if you adhere to all the
    component specifications. To do otherwise is folly.
    A more fruitful question might be, "Which vendors SPECIFY the longest
    refresh interval?"
    Soapbox off...
    mike
    Wanted, Serial cable for Dell Axim X5 PDA.
    Return address is VALID but some sites block emails
    with links. Delete this sig when replying.
    FS 500MHz Tek DSOscilloscope TDS540 Make Offer
    MAKE THE OBVIOUS CHANGES TO THE LINK
    ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
  10. Pooh Bear
    Pooh Bear Guest
    It's not about processor load. You can't read / write memory when it's being
    refreshed.
    Also please don't top post Boki.
    Graham
  11. Pooh Bear
    Pooh Bear Guest
    Does it ? Hadn't heard that.
    Graham
