what's the different between switched capacitor and switched opamp technique?
Discussion in 'Electronic Design' started by Boki, Jul 30, 2003.
  1. Boki
    Boki Guest
    Hi, All:
    What's the different between switched capacitor and switched opamp
    technique?
    Thanks!
    Boki.
  2. Never head of a switched op-amp. Do you mean a chopper amp? If so, a
    chopper amp is designed to give low offset voltage, a switched capacitor
    device is usually taken to be a filter.
    Kevin Aylward
    http://www.anasoft.co.uk
