What's a Joule?
Discussion in 'Electronic Basics' started by Chris Williams, Oct 27, 2004.
  1. I am teaching myself from Thomas L. Floyd's "Principles of Electric
    Circuits". So far (chapter 4) it seems that he has done a good job
    describing all of the units and how they should be visualized except
    for Joules (energy.) This he pretty much just says is "the amount of
    available energy" but without making it any clearer.
    It would appear that fundamentally everything boils down to 1.) the
    quantity of electrons (Q), 2.) time (t), and 3.) energy (W.)
    Q = Total quantity of electrons
    t = time spent doing something with the electrons
    W = "the amount of available energy"
    So current is easy:
    I = (number of electrons) / (time)
    Rate at which electrons were moved (through a wire)
    But voltage is problematic:
    V = (W?) / (number of electrons)
    Rate of "the amount of available energy" to the number of electrons
    ....which isn't terribly clear
    Reading over the text a couple of times, and I am thinking that
    voltage is the electrical version of "pressure"...?
    So in water/piping terms, pressure would be a function of a) the
    amount of water and b) the amount of "push" it had to make it want to
    go into a pipe. Push would then be a product of gravity, mechanical
    pumping, etc. So assuming that this is true then W == "Push."
    Pressure = "Push"(kg) / Water(cm^2) for instance
    So this allows me to understand a Volt
    Voltage = "Push"(joules) / Electrons(coulomb)
    But what is the electric version of "push"?
    My current guess is that this is the total "negativity" or
    "positivity" of a terminal on a power source. Which--in the case of a
    battery say--would be the ratio of positively charged atoms to neutral
    atoms in a positive electrode, or the number of free electrons to the
    total number of neutral atoms in the negative electrode...?
    Is this reading correct?
    Thank you,
    Chris Williams
  2. or, the way I prefer to think of it,
    I = dQ/dt
    Instantaneous change in Coulombs divided by the instantaneous change in time.
    (When it is expressed using finite values, then these must by definition amount
    to average quantities and are never really precise for any instant in time.)
    Joules per Coulomb, yes. But... Think of it this way....
    Set up two plates in a vacuum, somewhere in an otherwise empty universe.
    Provide 1 Volt of potential difference across these plates (we'll figure out
    what that is in a moment) and set a Coulomb's worth of electrons over near the
    surface of the one that is more negative, so that they are accelerated towards
    the other plate. Eventually, they will travel across the intervening space and
    will strike the other plate. When they do, the net energy of the impact will be
    1 Joule. Release two Coulombs to start and the net energy of the impact of that
    many will be two Joules. And so on. And it doesn't matter how far apart the
    plates are moved. If they are close together, the electrons will be accelerated
    more and take less time to arrive, but their final velocity will be the same
    when they hit and the resulting energy of the impact will be the same. Further
    away, they will take much longer and be accelerated more slowly, but they have
    much further distance over which to gain their velocity and they will arrive
    again with the same impact energy. Hence, Volts is expressed as Joules/Coulomb
    and doesn't need to include the distance between the plates.
    Don't forget that:
    Ohm = Joule-second/Coulumb^2 = Watt/Amp^2 = Henry/second
    Watt = Joule/second
    Henry = Joule-second^2/Coulomb^2 = Joule/Amp^2 = Ohm-second
    Farad = Coulomb^2/Joule = Coulomb/Volt
    If you then look at an "RC time constant," this is:
    R*C = (Joule-second/Coulomb^2)*(Coulomb^2/Joule) = second
    Nice, eh? Time, as you might expect. Also, take a look at the SQRT(L*C), which
    is:
    SQRT(L*C) = SQRT((Joule-second^2/Coulomb^2)*(Coulomb^2/Joule))
    = SQRT(second^2)
    = second
    Once again, time! Dimensional analysis to the rescue.
    Jon
  3. By the way, this "final velocity" won't be the same if you were propelling a
    Coulomb's worth of protons instead of electrons, as they are nearly 2000 times
    as massive and the force will impress a much lower acceleration on them. But
    the net energy at impact should be the same. Since potential energy is
    proportional to M*V^2, I'd anticipate that the velocity of the protons at
    arrival would be about the square root of the ratio of the mass of the electron
    to the mass of the proton, or about sqrt(1/1836.15266) = .02334 times as fast.
    A little more than 2% of the speed that the electrons would achieve. (Assuming
    neither case was approaching relativistic speeds, of course.) Same energy,
    though.
    Jon
  4. Chris,
    Voltage is often compared with pressure and it's not a bad comparison. But I
    guess your description of pressure is not correct so you will fail to
    understand voltage as well. Pressure has nothing to do with amount. The
    "potential" of water depends on its height (due to gravity) no matter the
    amount of water. It may be either a raindrop or a reservoir. Only if you
    look at the energy the amount becomes important.
    Power has to do with the available energy per second. Even a filled
    reservoir can deliver little energy/second if you have only a 1" pipe. But
    when the weir breaks... Another example is a flashlight battery. Its amount
    of energy is comparable with the energy of a thunderflash but you need at
    least minutes to empty a battery. A flash delivers its energy in a split
    second.
    petrus bitbyter
  5. John Larkin
    John Larkin Guest
    That's a good model: the voltage on a conductive object represents the
    density of electrons, where zero volts means the number of electrons
    just equals the number of protons.
    So voltage is charge density on a conductor. Measured in volts.
    Current is the rate of flow of charge from one conductor to another,
    in amps. If there's a conductive path between the charged things, the
    voltage difference tends to push charges along that path; more voltage
    difference, more push.
    Power is the current flow multiplied by the voltage difference between
    the conductors involved; watts.
    Energy is the time integral of power; watt-seconds, aka joules.
    Two nearby conductors at different voltages constitute a charged
    capacitor, which stores some joules of energy. If current is allowed
    to flow between them long enough for the voltage difference to vanish,
    the stored joules will have been dissipated as power over the time it
    took to discharge the system. If a resistor was used as the conductive
    path, those joules would have heated up the resistor, which is where
    the stored energy went.
    John
  6. Nope. Electromagnetic energy (Joules) are nothing like a "push."
    Voltage is not pressure, but it's connected. Voltage is more like
    the depth of water. Potential difference between conductors is
    like the height difference between two lakes: connect them and
    there will be a flow. Voltage is also like the height of a hill
    up which we roll a boulder, with the charge being the boulder's mass.
    In that case the potential energy of the boulder is "Joules."
    The higher the boulder (i.e. the higher the voltage,) the more
    Joules are stored as potential energy... and the greater the
    mass, the greater the energy. Joules = height * mass,
    and Joules = Volts * Coulombs.
    Another note: whenerver circuits are involved, the energy is
    electromagnetic energy, and it's made of e-fields or b-fields
    (or both.) In other words, the Joules have a particular location.
    The Joules stored in a capacitor are stored in the insulating gap.
    The Joules transmitted along a wire are in the space surrounding
    the wire.
  7. Rich Webb
    Rich Webb Guest
    What goes Erg! ? A dyn' centimeter, of course.
  8. Don Kelly
    Don Kelly Guest
  9. Yes, I'm aware of it. I still prefer to think in terms of countable things,
    though. Penchant of mine. Still, there are a variety of commensurate systems
    to the SI system. One I like is a relativistic mapping, which makes length and
    time the same, describing everything in a 'pure' number of light-seconds.
    Jon
  10. Ok I believe I understand correctly now--I was a bit off.
    Floyd's description of "potential energy" was throwing me off as, how
    do you evaluate the total potential energy of a mass? If you have a
    boulder just sitting there on the ground, how much energy does it
    "potentially" have? Well that kind of depends on what you do with the
    boulder afterwards (like rolling it up a hill.)
    I was mistakenly thinking of the boulder (or water) in it's starting
    state, instead of it's final moment of impact.
    So:
    Voltage = Current * Resistance
    Voltage is the product of the speed and the resistance. So in water
    terms, you will have greater pressure by using a smaller pipe
    (increasing resistance) just as you will need a greater amount of
    pressure to increase the flowthrough if the size of the pipe stays the
    same.
    Voltage = Energy / Quantity
    Energy = Voltage * Quantity
    The greater the amount of force on a certain body, the greater the
    amount of energy we will have _at the time of use_. Similarly, a
    larger mass being delivered at the same amount of force will have more
    energy _at the time of use_.
    Does this seem correct?
    -Chris
  11. Don Kelly
    Don Kelly Guest
    I like the stone, furlong, fortnight, standard stroke of a standard glass
    rod on a standard cat. system or the
    SFF Damncatclawedme system of units :)
    (actually I am old enough to prefer using the Coulomb to the ampere in
    dimensional analysis)
    Take care,
  12. Don Kelly
    Don Kelly Guest
    Basically OK
    OK but "quantity" needs further refinement.
    You are getting closer but you are mixing mechanical and electrical terms-as
    well as mixing up energy and power concepts. You can have a force on a body
    but if it doesn't move- no energy is involved. You can have a voltage source
    but if it is open circuit (no current) then there is no energy involved. If
    you have a current due to this voltage, then you will have power =V*I but
    power is the time rate of change of energy so the energy will depend on both
    power and time. Mechanically a force times a velocity is power but velocity
    is distance/unit time so energy includes a time factor.
    Voltage or potential difference between a and b is defined in terms of the
    energy per unit charge to move the charge from a to b in an electrical
    field. This is energy or work and is expressed in Joules (1 watt-second=1
    Joule). It can exist whether or not there is a current. Certainly, in a
    given field, it will take 2 times as much energy to move 2 Coulombs as to
    move 1.
    The analogy would be the energy needed per unit mass to move a mass from
    point a to point b in a gravitational field. This also is expressed in
    Joules. More energy is needed to lift 2kg than to lift 1 kg.
    In either case, it doesn't matter how long you take or what path you take-
    the energy depends on the end points. In the case of a mass being lifted
    from a to b, the mass could be lifted up directly against gravity or slid up
    a long ramp- the energy change depends on the initial and final heights in
    the gravitational field. Ditto for the movement of a charge in an electrical
    field. Small force over a long time or higher force for a shorter time =same
    energy
    Current at a point is the rate of change of charge passing that point.
    Coulombs/second
    A voltage or potential is needed to produce a current (except in true
    superconductors which aren't available at Radio Shack)
    An analogy is the total flow rate in a river at some measuring point- say
    gallons/minute. This flow is produced by a pressure difference or head (eg.
    potential difference).
