What would happen IF?
Discussion in 'General Electronics Discussion' started by Burnmeup, Aug 6, 2014.
  1. Burnmeup
    Burnmeup
    10
    Aug 4, 2014
    Hello everyone,
    I want to use my Linear power supply BUT it is a German model. I purchased it when I was in Germany 2 years ago. It is 220v 50hz, without using a step up/down transformer is it possible to run this unit here in the USA without any incident?
    Burnmeup
  2. davenn
    davenn Moderator
    13,877
    1,964
    not unless it has a 120V/220V switch on the back of it
    you only other 2 choices are ... step up transformer from 120 to 220V
    or replace the transformer inside the PSU
    cheers
  3. (*steve*)
    25,497
    2,839
    edit: Ignore everything I said. It's a linear supply.
    Check carefully. The input power might be specified as something like 85 to 265VAC. If so (or if it is a range that encompasses the supply voltage in the US) then you're OK.
    oh, this bit's probably OK:
    If you have a 220V outlet then you can run it from that too, but I gather they're not common except behind electric stoves etc.
  4. cjdelphi
    cjdelphi
    1,096
    104
    Oct 26, 2011
    Best off not using it and buy a 110v rated transformer, finding the correct sized transformer remounting it... the trouble it would cause you..
    Another option is to buy a 110 to 240ac transformer just so you can use your german 240v...
    Hardly worth the effort or power loss stepping up down and around around!
