What would be a good way to....
Discussion in 'Electronic Design' started by Motty, Oct 14, 2003.
  1. Motty
    Motty Guest
    Here's the deal: I am designing and building a ring modulator for a
    guitar effect. I have two signals - the guitar - and a function
    generator output signal (Max038 chip) going into a Burr Brown
    multiplier chip. The problem I am facing is that I need a way to turn
    off the output from the circuit when the guitar is not producing a
    voltage (or current). Since the output is two signals mixed together
    I don't want the function generator signal to show up on its own (when
    it is not being multiplied by the guitar signal). This would just
    produce a tone at the output. Hopefully this makes sense.
    I was thinking of some type of transitor switch circuit, but I would
    have to go back and look at my books really hard. Does anyone have a
    suggestion as to how to design a voltage controlled switch? The raw
    output of the guitar is a +,-200mV signal at the MAX. Usually it is
    in the 10-100mV range centered around ground.
  2. In a multiplication, if one of the factors are zero
    the product (=output) will also be zero, not ?
    Or maybe the multiplier isn't perfect...
    Jan-Erik.
  3. As Jan-Erik stated, your multiplier is not perfect, but anyway:
    Switching the output signal on and off would create clicks, I would use an
    NE570, with the guitar signal into your rectifier, and the VCA after the
    multiplier. With a capacitor, and a current limiter at the output of your
    rectifier it's done.
  4. But the mixer should be balanced, or else you'd be bothered with
    the oscillator signal and the guitar signal being at the output all
    the time. Remove the guitar or oscillator signal, and there should
    very little signal at the output of the mixer.
    Maybe you didn't catch that, and anticipate a problem that isn't
    there.
    If you notice too much output with only one signal to the mixer,
    then you might want to look at a different mixer, or see if there
    is a way of balancing the mixer through an external DC bias.
    Also, perhaps layout is a factor. If the oscillator is strong enough,
    and layout is wrong, the oscillator might be getting around the mixer
    through inductive pickup on the wires. For that matter, if the power supply
    line is not bypassed properly, the oscillator signal could be flowing on
    the voltage supply line(s).
    I seem to recall some IC mixers that did not work so well if the signal
    levels were too strong. So that might also be a factor to watch.
    Michael
  5. N. Thornton
    N. Thornton Guest
    Another option is to use your tone to just control the gain of a
    circuit. Using a FET is a very easy way to do this.
    Regards, NT
  6. Michael
    Michael Guest
    Maybe the multiplier is fine, and the problem is the hiss from your
    guitar when your not playing, if thats the case you can get a pedal
    which does a noise gate. Maybe if the idle noise was quiet enough this
    noise gate might work on the output of your multiplier?
