What will happen if point A short with ground
Discussion in 'Electronics Homework Help' started by strameshkumar, Mar 12, 2012.
  1. strameshkumar
    strameshkumar
    25
    Feb 23, 2012
    In this H-Bridge circuit, What will happen if point A short with ground 1.png
  2. Harald Kapp
    10,609
    2,370
    Why should anything happen? Think about what the other transistors do.
    Harald
  3. strameshkumar
    strameshkumar
    25
    Feb 23, 2012
    Q3 will conduct and Q4 won't conduct, but high current may damage the Q3 transistor.
    My ques is if i use power mosfet, what wil happen either motor get damage or mosfetwill get damage? and How?
  4. (*steve*)
    25,419
    2,790
    Replace Q4 with a link. Assume all transistors are off.
    Now go through all the combinations of turning transistors on (start with turning one on at a time.)
    Where does the current flow?
    Consider what could damage the motor. Is there anything?
    Now you know what will happen if any single transistor is turned on, what will happen in practical use? (for this you need to understand how an H-Bridge is used)
  5. jackorocko
    jackorocko
    1,284
    Apr 4, 2010
    Neither transistor will conduct with zero base current.
    Think about what harald said again.
