what wattage value would I use for the resistors in this schematic
Discussion in 'General Electronics Discussion' started by adrian21f, May 28, 2015.
  1. adrian21f
    adrian21f
    3
    May 27, 2015
    The parts are: R1=10k, R2=2.2K, R3=100 C1=47uF/50V, C2=2.2nF, C3=10pF, SW=switch, B=Battery 9V.
    The coil L should be closely wound 5 turns (start tunning with the closely wound distance of turns and then play with it and the C4 capacitor, to find the desired frequency )of enameled copper wire 1.5mm and internal coil diameter of 1cm (leads 2x20mm).
    The variable capacitor C4 should be air trimmer capacitor rating 4 to 30 pf or the closest to this value.
    As for the transistor Q its the 2N3553. Its a RF Power Silicon NPN Transistor in a TO39 type package designed to be used in amplifiers and oscillator applications in military and industrial equipment.
  2. Fish4Fun
    Fish4Fun So long, and Thanks for all the Fish!
    464
    105
    Aug 27, 2013
    Hey Adrian21f ! Welcome to the the forum!
    So assuming the nominal circuit voltage is 9V * 3 = 27V, and the smallest resistor (r3) = 100 ohms a first order approximation would go something like this:
    Code:
    E = iR --> 27V = i * 100 ==> Imax = 0.27A = 270mA
    P= iE -> 0.27A * 27V = 7.29W ==> r3 Power rating ~10W
    Or, more simply:
    P = E^2 / R
    But obviously this is over-kill.....The circuit is some type of RLC resonant oscillator, and the actual current in r3 is dictated by the impedance of c4 and L at the tuned frequency, the DCR of L, ESR of c4 and the conductance of Q. You might have a look @ this: http://hyperphysics.phy-astr.gsu.edu/hbase/electric/serres.html#c1 , this http://hyperphysics.phy-astr.gsu.edu/hbase/electric/parres.html#c1 , and this http://hyperphysics.phy-astr.gsu.edu/hbase/electric/impcom.html#c1 .
    My gut feeling is that r3 should be rated @ ~ 1W to 3W and if I were building it in a hurry and wanted to be certain it would work w/o doing the math then I would likely go with 10 * 1/2W 1k in parallel, or 10 * 1/2W 10 ohm in series.....but that is CERTAINLY NOT because I did the math....
    To be honest this looks a lot like a homework problem, so I hope if this is the case you will take the time to read through the links and actually do the math; regardless it would certainly be sloppy practice NOT to do the math.
    Good Luck!
    Fish
    Arouse1973 likes this.
  3. adrian21f
    adrian21f
    3
    May 27, 2015
    wow thanks... very helpful and easy to understand ill for sure take a look at those.
  4. Colin Mitchell
    Colin Mitchell
    1,417
    312
    Aug 31, 2014
    Just use 0.25w resistors
  5. (*steve*)
    25,418
    2,788
    Just to add to the discussion, the average voltage across R3 is going to be about 0.6V lower than the dc bias point of the base. That's about 1/6 of the supply voltage, or about 4.5V.
    I'll leave it as an exercise to the reader to determine if Colin's advice above is appropriate. :)
  6. BobK
    7,682
    1,686
    If that was meant to be a hit a Colin, it doesn't work out that way.
    4.5-0.6 = 3.9
    3.9 ^2 / 100 = 0.15 W, so 1/4 W is fine.
  7. (*steve*)
    25,418
    2,788
    It wasn't meant to be a hit at Colin :)
