What vibration sensor for bearing monitoring
Discussion in 'Sensors and Actuators' started by screwball, Oct 15, 2017.
  1. screwball
    screwball
    89
    Jan 9, 2012
    I am looking for a vibration sensor which would be suitable for monitoring bearing condition, the only sensors I can see are listed as tilt sensors or switch on shock, any pointers in the right direction?
  2. kellys_eye
    kellys_eye
    4,276
    1,146
    Jun 25, 2010
    AFAIK they use piezo transducers and monitor the frequency of the signal to detect vibrations.
  3. Externet
    Externet
    736
    158
    Aug 24, 2009
    hevans1944 likes this.
  4. hevans1944
    hevans1944 Hop - AC8NS
    4,468
    2,083
    Jun 21, 2012
    Single-axis accelerometers are what we used in our bearing test rigs. Bearing failure, indicated by a sudden increase in vibration amplitude, initiated shutdown of test rig. Most vibration accelerometers use a "proof" mass attached to a piezoelectric crystal to form an accelerometer transducer with excellent high-frequency response. More recent variants use MEMS (Micro-Electro-Mechanical Systems) technology, but the principles are the same: measure the motion of a test or "proof" mass with some sort of position transducer.
    Here is a pretty good introduction from a company that has been in the instrumentation and data acquisition business a long time. You might also want to check out the links on this Google search results page.
    davenn and kellys_eye like this.
  5. OBW0549
    OBW0549
    159
    118
    Jul 5, 2016
    If you simply Google the phrase, "vibration sensor for bearing monitoring" you'll get all kinds of good info. Bearing condition monitoring is a well-established science/art, and so are the devices and methods for doing it.
  6. Externet
    Externet
    736
    158
    Aug 24, 2009
  7. hevans1944
    4,468
    2,083
    Jun 21, 2012
