What type connector is this.
Discussion in 'General Electronics Discussion' started by mrel, Sep 2, 2018.
  1. mrel
    mrel
    109
    Jul 2, 2008
    Hi
    Anyone know what is this connector use on this volt/amp meter call ,see enclosed picture.
    On ebay they sell connectors name Jst some say (Jst ph,jst xh,,jst sh, micro mini jst -sh1.0mm,micro mini jst 1.25mm,mini micro jst 1.5 mm and more different mms ).
    The picture enclosed is this connectors Jst or some other name?
    These Jst connector sell on ebay what is these number in mm mean is this the pin size of the connector or is it the housing size of the connectors.
    On you tube some people call the connector Pico Blade other call Jst what is right name for these connectors?
    mrel
  2. VenomBallistics
    VenomBallistics
    285
    57
    Aug 30, 2018
    looks like the balance plug on LiPo batteries used in RC .... we call em JST connectors
    davenn likes this.
  3. Bluejets
    Bluejets
    5,257
    1,102
    Oct 5, 2014
    There are different versions of jst as you have already stated.
    It will depend on pin pitch.
    Most balance plugs are 2.5 which make them JST-XH.
    They come in a varity of pin numbers.
    If you do a Google search you should be able to find a table which outlines the different ones.
    Just be aware when you buy off Ebay as I recently did, check when they arrive as you could end up with the smaller 2mm pitch.
  4. mrel
    mrel
    109
    Jul 2, 2008
    What do you mean pitch is it spacimg between the pins or pins size?
    mrel
  5. davenn
    davenn Moderator
    13,948
    1,990
    spacing between pins
  6. WHONOES
    WHONOES
    1,190
    322
    May 20, 2017
    The JST bit stand for Japan Solderless Connectors which I guess as a description is not strictly true.
