What to Do With a Lot of Salvaged Speakers?
Discussion in 'Audio' started by Sarah Szabo, Jun 2, 2018.
  1. Audioguru
    Audioguru
    2,726
    615
    Sep 24, 2016
    Correction to what I previously typed:
    2) Connect two speakers (especially the same kind) in series to the output of a modern low output impedance amplifier and tap the cone of one. The resonance will be damped only a little.
  2. BobK
    7,673
    1,684
    I can see @Audioguru's point. Putting the speakers in series adds a resistance to the circuit between one speaker and the amplifier the same way adding a resistor would. What would happen to the damping factor of a modern amplifier if you added an 8Ω resistance in series with the speaker? It would become 1, no?
  3. Audioguru
    Audioguru
    2,726
    615
    Sep 24, 2016
    The impedance at resonance of many 8 ohm speakers is 40 ohms so having two in series produces no damping at resonance.
    The damping factor of a modern amplifier is more than 400 so its output impedance is less than 8/400= 0.02 ohms. Then the speaker does exactly what the amplifier signal does. A loose undamped speaker "does its own thing".
  4. FuZZ1L0G1C
    FuZZ1L0G1C
    367
    115
    Mar 25, 2014
    I did a similar experiment long ago, (1970's) using a diaphragm-ripped 80W 4" 4-ohm Pioneer car speaker.
    The center-cone was epoxied to a small plastic tube, itself epoxied to a square of Paxolin (PCB).
    Four springs from old 'Ding-dong' doorbells supported a salvaged voice-coil wired to a preamp via twisted-pair Litz wire. Salvaged center-magnet-on-rod formed the core. All enclosed in long box. Amplified guitar 'Spring-reverb' used to drive my parents nuts when practicing "Crimson & Clover" riffs.:cool:
    darren adcock likes this.
  5. FuZZ1L0G1C
    FuZZ1L0G1C
    367
    115
    Mar 25, 2014
    Maybe you could network several identical speakers to create a virtual "larger diaphragm" driver, feeding a wooden labyrinth enclosure. Books such as @Bobnoes mentioned have construction details.
    As for surround, it depends on the source device.
    Some amps have line outputs (usually RCA phono sockets), which would need amplification or attenuation.
    If you don't yet have surround, there are circuits (and kits) for stereo>surround encoding.
    Cabinet Dimensions: The 321 ratio is a good place to start.
    3 x = height; 2 x = width; 1 x = depth.
  6. Audioguru
    Audioguru
    2,726
    615
    Sep 24, 2016
    One cheap speaker sounds like a cheap speaker:
    1) A high resonant frequency with no deep bass.
    2) A peak in the upper midrange with no highs.
    A network of these speakers will sound the same but can be louder than just one speaker.
    A large "super diaphragm" will be very directional.
