R
robb
I changed the CRT HV anode wire on TEK o'scope by ...
- removing the silicon glued cover/cap
- desolder old anode lead
- clean silicon
- solder new anode lead
- re-silicon the lead cover/cap
Now ? is there any test i should perform to make sure i did the
job correctly/well ?
Like checking for corona leaks or any other such matters ?
Best method to do these tests
Also i noticed the Aquadag coating on the good CRT is alot more
uneven (bumpy) is there anything that should be done with the
Aquadag ?
Any useful ideas and help appreciated.
robb
- clean silicon
Aquadag ?
robb
