What kind of rechargeable cell do I replace this with?
Discussion in 'Troubleshooting and Repair' started by NuLED, Nov 25, 2013.
  1. NuLED
    NuLED
    294
    Jan 7, 2012
    Hi folks,
    I took apart an old iPhone recharger which had a swollen battery pack.
    I am now, not sure what OEM product I can replace it with, or if I can even expand the capacity with a much larger battery. I don't care about aesthetics. I just want to have it working, and supply sufficient voltage to charge the iPhone and iPad, at a reasonable current.
    Please see the photos I took. I had to cut off the battery terminals, which were flat.
  2. mikey5791
    mikey5791
    171
    16
    Jun 7, 2013
  3. virtuetovice
    virtuetovice
    Nov 29, 2013
    You must stick with the same voltage, but a higher milliamp/hr rating(mAH) will do nothing but increase battery life. For example, a 2000MAH battery will last much longer than a 500MAH battery. However, the battery NEEDS to be the correct voltage.
