What kind of lead should I use?
Discussion in 'General Electronics Discussion' started by Chengjun Li, Nov 30, 2014.
  1. Chengjun Li
    Chengjun Li
    84
    7
    Oct 21, 2014
    Hi, I have a PGA chip(attachements). I wonder what kind of leads can I used to connect the pins in the PGA chip, just like shown in attachments?
  2. (*steve*)
    25,480
    2,828
    You would use a socket. That would be mounted on a PCB.
  3. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    That's 100 pins you have to worry about. Using leads on a large number of pins will make it much easier to accidentally cross your leads resulting in damage.
    Perhaps you should tell us the intended purpose, and if you really really wanted to... you could solder some leads to a select few pins you plan to use. Other than that, use a socket, solder it to a board. Perhaps google around for a 'break-out' board that you can use during development.
    KrisBlueNZ likes this.
