what kind of fuse?
Discussion in 'Misc Electronics' started by palito, Sep 15, 2005.
  1. palito
    palito Guest
    I have a 12v timer/relay powered by a 12v marine battery. Timer is powered
    by battery and has a relay that passes through the load acting as on/off
    switch. Instructions say to put a 1 amp fuse between power and battery.
    I can only find 1 amp 250v slow or fast acting fuses at Radio Shack.
    Will either the slow or fast acting fuse do the job or is there more I need
    to know to wire this in?
    Pat
  2. CWatters
    CWatters Guest
    12V fuses are usually available from car/auto parts shops.
