What is used so that the plates of circuit look green color?
Discussion in 'Electronic Basics' started by [email protected], Jan 14, 2006.
  1. Guest
    Anybody knows what can be used so that the plates of
    printed circuit look green color?
    Some special painting is used or can be used any varnish
    mixed with green painting?
    Thanks in advance for any help.
  2. Pooh Bear
    Pooh Bear Guest
    What do you mean by 'plates' ?
    Graham
  3. JeffM
    JeffM Guest
  4. Yukio YANO
    Yukio YANO Guest
    "Solder Masking" a special Lacquer, paint, ink? to limit the creeping of
    melting solder especially during re-flow soldering, colored green to
    accent the difference between coated and uncoated copper !
    Yukio YANO
  5. The green colour of commercially-made PC boards comes from the solder
    mask - a coating that is applied to the board (possibly by silkscreen)
    after the board is etched.
    Peter Bennett, VE7CEI
    peterbb4 (at) interchange.ubc.ca
    new newsgroup users info : http://vancouver-webpages.com/nnq
    GPS and NMEA info: http://vancouver-webpages.com/peter
    Vancouver Power Squadron: http://vancouver.powersquadron.ca
  6. Jasen Betts
    Jasen Betts Guest
    green lacquer if transparent green paint if not.
    probably a paint with heat resistance upto 250 C would be a good idea.
    (if you intend to solder after painting) VHT makes heat resistant paint
    in spray cans. (try hot rod parts places)
