Components
Hi there Genestealer.
Those are power resistors, one looks like 50 ohms, another has 10% on its, thats its tolerance under operating conditions in temperature of the resistor, for a power resister to end its life like that its either damp moisture, or intense heat, looking closely at the base of the damaged resistor it looks like charring, darker discoloration, but from the pic's its hard to tell, any way something failed to allow the resistors temperature to rise out of its rated temperature region, although some damp might also be responsible, it hard to tell from pic's.
Your be able to get the parts i expect, but if the unit works again is any ones guess.
And if its a mains device, and that is heat damage, i dont think i would take the risk of repair, more like replace the whole unit with a new one. Dave.
PS sorry a car, ok you need to find the power rating of the damaged resistor, some research on the vehicles data might help, its got to be the correct resistance and power rating, there is also what looks to be a large transistor, or a thermal package, you wont know the extent of the damage until you replace the resistor and try the climate control.
