What is this? Does it look fried?
Discussion in 'Troubleshooting and Repair' started by petedw, Apr 17, 2010.
  1. petedw
    petedw
    6
    Apr 17, 2010
    I'm trying to fix my a/c unit in my car. It has a digital display. I think this part if fried and I'm trying to figure out what it is.
  2. Externet
    Externet
    795
    174
    Aug 24, 2009
    Both the PNP transistor and the 100? Ohm resistor seem fried.
  3. (*steve*)
    25,501
    2,841
    The transistor or the resistor? The resistor looks like it's been pretty hot.
    Is there any particular reason you suspect these parts?
    edit: Externet -- why do you think the transistor is fried, and how do you pick it for PNP. I can't decipher a part number (or at least one I can locate). The stuff on the tab of the transistor looks to me like it's from whatever is being used to prevent the nut from shaking loose.
  4. petedw
    petedw
    6
    Apr 17, 2010
    Resistor common problem
    People say that the resistor works as a fuse on these units and burns up when other things are bad. I changed out my resistor with some capacitors, but unit started smoking. Resistor was frying again and I just happened to notice how how that (transistor?) was and did not remember the black stuff on top of it. Is there a way to test it and do the numbers on top mean anything? They are .T B1019 Y 1A. Thanks for any help.
  5. (*steve*)
    25,501
    2,841
    I'm sure the numbers mean something, but I'm afraid they look like the manufacturer's internal part numbers. They get them with "special" markings with the side effect of making the device harder to service by people without the knowledge of what this translated to.
    If the black stuff on the transistor looks and feels like the stuff keeping the nut secured, then it's probable that you simply failed to notice it.
    The device it marked on the board as a transistor, so it probably is :) What sort is another question...
    You said you replaced the resistor (and it looks like it). Are you sure you replaced it with the same value? You seem to have discussed this problem with other people. Do any of them know what type of transistor it is? I don't suppose you have a circuit diagram for this?
  6. petedw
    petedw
    6
    Apr 17, 2010
    Oh, yes it is marked as a T on the board for transistor. Thanks, I don't really know what I am doing, but am hopefully learning. Many others on the auto forum I have been reading changed the resistor and used the one I used (1ohm 1watt). Unfortunately no one has a circuit diagram. The black stuff feels hard and I feel like when I zoom into a picture that it may be burned plastic, but can't be sure. Is there anyway to determine what I would need to replace it with?
  7. (*steve*)
    25,501
    2,841
    Firstly it would be useful to know if the correct value is 1 ohm.
    Secondly it would be useful to know what transistor people have replaced this with *and* have got it working again.
    If the substance comes off with a little prodding and looks like carbon (from the epoxy most likely) then it's a bad sign. See if there's a short across any pair of the leads of the transistor. Note that components in the circuit may have a low resistance, so this is not definite.
  8. petedw
    petedw
    6
    Apr 17, 2010
    I know that the resistor is the correct one. I have not found anyone who has replaced the transistor. There is no short between the leads, but the stuff chips off and has the same color to it as the transistor itself. Is there any hope for finding a proper replacement?
  9. Resqueline
    Resqueline
    2,848
    Jul 31, 2009
    The transistor is made by Toshiba and is a 2SB1019. This seems like it could be part of a switchmode inverter circuit by the look of the toroid beside the transistor.
    The "oozing" stuff may simply be blackened glue used to fix the nut. The transistor need not be damaged even if it's been hot.
    Can you post a bigger & more overlooking picture, and also of the backside of the board, so that we may have a chance of "dechiphering" the circuit?
  10. Externet
    Externet
    795
    174
    Aug 24, 2009
    Transistors starting A,B are abreviated from 2SA, 2SB and are PNP. Transistors starting with C, D are abbreviated from 2SC, 2SD which are NPN. Japanese 'save ink' :rolleyes: stamping them that way.
    The resistor is a flameproof type to prevent fires on obviously fire prone circuits; it may be in series to such transistor, which means the transistor shorted and passed overcurrent to the resistor, so both are suspected fried.
    The reason why the transistor fried first has to be investigated, as what does it drive/supply power to. (a solenoid? A fan?) And fixed first. As just replacing them will let the smoke escape again.
    Edited: added---> Looking at the pictures, Seems that transistor upconverts 12V to ~ 200VAC for the display operation.
    If you cannot find the parts of diagnose the problem, canibalize the module from a wreckyard, will be $5; cannot beat that.
    Edited again: 2SB1019: http://www.classiccmp.org/rtellason/transistors-2sb.html
    Miguel
  11. Externet
    Externet
    795
    174
    Aug 24, 2009
  12. (*steve*)
    25,501
    2,841
    <slaps head>
    Thanks for reminding me.
  13. jerryg50
    jerryg50
    57
    Apr 18, 2010
    Power Transistor Replacement
    It appears your transistor should be a 2SB1019 PNP high speed switching transistor.
    Below is the only free link (no cost for data) I could find for a data sheet on that transistor. It is a 2SB1019. The data sheet at the link is written in Japanese. But, the specs are in standard symbols and numbers. The transistor is a PNP high speed switching type. 0.1 usec. It's power factor is very high for its size.
    Data Sheet 2SB1019:
    http://www.classiccmp.org/rtellason/transdata/2sb1019.pdf
    In consideration of the application of the device, the problem can be a lot deeper than the transistor itself being the only component defective. Normally when these blow there is a cause.
    As for the circuit boards and modules, the automobile electronics manufactures would never sell or give out any circuit design information. The auto service people would swap out the circuit board or module for a new one when servicing. In considering the time involved and the fact there is no service support or info available, it would not be a consideration to service it at the board level.
    In your case, you can purchase a new transistor and see what happens after you replace it. The US cost of the transistor is about $6 to $10 each depending on where you buy it. Many dealers will have a minimum quantity purchase.
    Jerry G.
  14. petedw
    petedw
    6
    Apr 17, 2010
    Thank you. You all have been very helpful
  15. Tesla
    Tesla
    165
    May 10, 2010
    This wouldn't happen to be for a 2004 Honda Accord would it ?
  16. warged
    warged
    Apr 29, 2010
    Yes and the resistor also
  17. Tesla
    Tesla
    165
    May 10, 2010
    Nevermind ... I found the large dropbox pictures and I see that it is not.
    I'll just add that the 2004 Honda Accord has a similar problem on the Climate Control/Radio display board. It's pretty easy to fix yourself if you are handy. However, many Honda dealers will replace the unit for free, even if you are out of warranty
    (goodwill repair).
