What is this device called?
Discussion in 'General Electronics Discussion' started by Moha99, Apr 3, 2013.
  1. Moha99
    Moha99
    261
    Nov 18, 2011
    There is this device that you connect it to the wall socket, and you can control the amount of Voltage that is used, and also know the amount of Current that is being drawn.
    Thanks.
  2. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Adjustable power supply...
  3. Moha99
    Moha99
    261
    Nov 18, 2011
    Thanks.
  4. Moha99
    Moha99
    261
    Nov 18, 2011
    I assume current and voltage can be controlled from the power source?
  5. Moha99
    Moha99
    261
    Nov 18, 2011
    Or is there a twist?
    Like if I controlled the current that woud change the voltage? Or would they stay constant as I change those values?
  6. donkey
    donkey
    1,293
    56
    Feb 26, 2011
  7. (*steve*)
    25,497
    2,838
    But only the voltage OR the current can be controlled at any one time.
    Typically the voltage is regulated until the current limit is reached. At this point the current is limited to that and the voltage will fall in order to restrict the current.
