Thank you 73's de Edd,
For the info and time to help. Love your name btw. 73 is my favorite # after 13.(my b-day)
thank you for the spec. correction. I cant really make out the (105) but it makes more sense now.
I do have the rest of the system. (photos attached). I acquired a nonworking but in very good shape 1980's Scanning Electron Microscope about a year ago. hence my previous post about the- big red block thing on my tables right consisting of 5 high power voltage doublers . but regrettably I did tear it down for parts for my various projects over the last year. Now I wish I hadn't done that!
I am now trying to piece it back together to better understand how the components were Assembled and ultimately dissect it and re-purpose these components to make a
-multi use, high currant, regulated, variable, multi out, bench supply.
Must include a 12v rail with at least 30Amps preferably more.
How did you get this info?
On the opposite side there is the + and – terminals of the 15VDC at ~ 120 ma output and a trim input to set ‘er rat on 15, if so needed.
The output voltage is what i was really after here, and the 120ma ? so in the model # MM15A. 15A doesn't imply 15 Amps? but as mentioned earlier, this is just a small part of the big picture.
I appreciate any help from the Electronics point community, As I love doing electronics but I have very little formal training mostly self taught consequently my electronics knowledge is limited.
So I'll post pics of some of the components i extracted from the microscope minus the fluke there in the middle
I'll explain more on them latter or as needed. with more details on my plan / schematics
