What is the use of FLUX when we solder?
E
Eeyore
To remove oxides / sulphides etc from the surfaces being soldered.
Graham
John Popelish
It combines with the surface oxide and excludes atmospheric oxygen
from making more oxide.
This allows the liquid metal (solder) to contact solid metal without
oxides being between them, which would inhibit their forming a thin
intermetalic layer that connects them together.
D
Don Bruder
Cleans the base metal(s) of the joint, both physically (floats crud
away) and chemically (eats various things that would keep the solder
form sticking), and prevents post-cleaning formation of an oxide layer
that would keep the solder from sticking.
B
Bob Myers
And most importantly, it gives you that wonderful
"I'VE been SOLDERING!" scent.....:)
Bob M.
D
Don Bruder
Bob M.
<heh> Yeah, there is that factor, now that you mention it :)
P
Puckdropper
IME, it has a tendency to warm parts through faster so you have to apply
the soldering iron for less time to make a joint. It seems I sometimes
get better joints when I use flux. (I'm not doing PC boards here, it's
soldering wires to model railroad rail.)
It's also useful for "recharging" desoldering braid.
Puckdropper
E
Eeyore
That's because it aids the 'wetting' of the components that in turn leads to
better thermal transfer.
Graham
Puckdropper
Don't notice that at all with a Metcal.
GG
