What is the most simple PA?
Discussion in 'General Electronics Discussion' started by rogerk8, Sep 20, 2013.
  1. rogerk8
    rogerk8
    176
    Jul 28, 2011
    Hi!
    I wonder how to build a very simple power amplifier.
    I would prefere to build it with descrete transistors.
    But how would my attached amplifier sound?
    Best regards, Roger
      File size:
      9.4 KB
      101
  2. davenn
    davenn Moderator
    13,894
    1,969
    hey Roger
    havent seen you for a while
    I think you will find there's a little more circuitry involved for a push-pull arrangement
    have a look here for an example
    typing discrete transistor amplifier circuit " into google images comes up with quite a few ideas
    DAve
  3. rogerk8
    rogerk8
    176
    Jul 28, 2011
    Hi Dave!
    Well I've been stuck at physics forum.
    Today I however got banned.
    Talked too much sex in my "Why do we need a spouse"-thread.
    I'm just laughing at it because how could you seriously not discuss sex in such a thread?
    Anyway, I am banned until 30/9 :)
    Take care Dave and thank you for your tip!
    Best regards, Roger
  4. rogerk8
    rogerk8
    176
    Jul 28, 2011
    What is actually the problem with my drawing?
    I mean, the OP will compensate for the unlinearities, will it not?
    I think it is as simple as it can be.
    Even though you still need some cooling arrangement (at least for higher output power).
    Best regards, Roger
  5. (*steve*)
    25,500
    2,840
    Theoretically, yes.
    Practically, no.
    The smaller you can make those non-linearities the better.
    Biasing the transistors so they're always slightly on is one way to do this.
  6. rogerk8
    rogerk8
    176
    Jul 28, 2011
    Hi!
    I have now designed a bridge-coupled version of the above for car usage.
    Doing the math I did however become disappointed of the fact that power output would be less than some 12W in 4 Ohm speakers. This while using Darlingtons as power BJT's. But this is almost neccesary if you want to use a standard OP which seldom can supply more than some +/-10mA. And while standard power BJT hfe is around 50 only, this would result in 500mA at output only.
    A way around this would be to use a high output current OP (along with ordinary BJTs). But they might not be available as rail-to-rail also, so the benifit kind of disappears.
    I say that my picture below is about the simplest way to design a car power amplifier without too much distorsion. Am I right?
    Best regards, Roger
  7. rogerk8
    rogerk8
    176
    Jul 28, 2011
    Hi!
    It struck me that the above amplifier has to be revised regarding bias.
    I have now designed a complete "Car Amplifier" which should take care of these problems.
    My only wish now is that I could find a dual J-FET rail-to-rail OP. But in the mean time TL072 will suffice (highest SR of the J-FET TL0x2-series).
    I think I will actually build this amplifier just to test the "bad" sound of the unlinearities :)
    Best regards, Roger
      File size:
      17.7 KB
      85
