What is the difference between Flash and PROM?
Discussion in 'General Electronics Discussion' started by charmcaster.engg, Jan 15, 2015.
  1. charmcaster.engg
    charmcaster.engg
    79
    Mar 20, 2014
  2. Harald Kapp
    11,642
    2,690
    PROM = program once, read many times. You cannot erase and re-program a PROM.
    FLASH = can be programmmed and erased many times.
    Different physical mechanisms are used for these.
  3. charmcaster.engg
    charmcaster.engg
    79
    Mar 20, 2014
    Thank you for the reply.
    Then how EEPROM and Flash differs?
  4. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    EEPROMs and Flash ROMs are both electrically erasable and reprogrammable. The differences are that EEPROMs are normally smaller than Flash ROMs; they are normally accessed serially (which is relatively slow) instead of in parallel like Flash ROMs; and they are erased and reprogrammed using a command-based interface; they may be reprogrammable in smaller chunks.
  5. charmcaster.engg
    charmcaster.engg
    79
    Mar 20, 2014
    Thanks!
  6. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    I should have said, to summarise, that EEPROM is used for data storage under program control, and Flash ROM is used for code to be executed directly by the MCU.
