what is sda setup time violation in EEPROM interfacing with PIC18F452
Discussion in 'Microcontrollers, Programming and IoT' started by billy2tom, Sep 29, 2010.
  1. billy2tom
    billy2tom
    Sep 25, 2010
    i simulated the pgm using c18 compiler. when i simulate in proteus i am getting
    error as sda setup time error. Can anyone help me plz...
    #pragma config OSC=HS, OSCS = OFF
    #pragma config PWRT = OFF, BOR = ON, BORV = 45
    #pragma config WDT = OFF
    #pragma config DEBUG = OFF, LVP = OFF, STVR = OFF
    #include<p18f452.h>
    #include<usart.h>
    #include<delays.h>
    #define SCL PORTCbits.RC3
    #define SDA PORTCbits.RC4
    int Transmit(unsigned char data);
    void Transmit_gui(void);
    int Start(void);
    void Stop(void);
    void Read24c64B(unsigned char RomAddress);
    void Read_eeprom(unsigned int e_add);
    void Ack(void);
    void NoAck(void);
    void init();
    void hex_ascii(unsigned char var);
    void display_USART(unsigned char disp);
    void New_Write_eeprom(unsigned char d);
    unsigned char Read8Bit(void);
    void delay(unsigned int itime);
    unsigned char buf[10] = {1,2,3,4,5,6,7,8,9,10};
    unsigned char a,d,indic,j,ReadData,s=0;
    unsigned int eeprom_data,data_msb,data_lsb,ia,Gui[16],Gui_Inc,i,k,Gui_Buffer,Gui_Buff[10],Msb,Lsb,Var;
    unsigned int device_add,Dt,Data;
    unsigned int lsb_add=10;
    unsigned int add_msb = 0,add_lsb = 0,x,b,c, AS_TEMP1,AS_TEMP2,var;
    void main()
    TRISCbits.TRISC3=0;
    TRISCbits.TRISC7=1;
    OpenUSART( USART_TX_INT_OFF & USART_RX_INT_OFF & USART_ASYNCH_MODE& USART_EIGHT_BIT & USART_CONT_RX & USART_BRGH_HIGH, 25 );
    Delay10KTCYx(100);
    while(1)
    New_Write_eeprom();
    delay(10);
    Read24c64B(s);
    delay(10);
    s++;
    display_USART(ReadData);
    putcUSART(' ');
    unsigned char b=0,c=0;
    unsigned int a;
    a = 0x80;
    for(b=0;b<8;b++)
    { c = 0;
    c = data & a;
    if(c==0)
    SDA=0;
    else
    SDA=1;
    SCL=1;
    for(d=0;d<8;d++);
    SCL=0;
    a = a>>1;
    SCL=0;
    return 0;
    Start();
    Transmit(0xA0);
    Ack();
    Transmit(0x00);
    Ack();
    Transmit(0x00);
    Ack();
    Transmit('d');
    Ack();
    Stop();
    lsb_add = e_add & 0xFF;
    device_add = (e_add / (0x100));
    Read24c64B(lsb_add);
    Start();
    Transmit(0xA0);
    Ack();
    Transmit(0x00);
    Ack();
    Transmit(RomAddress);
    Ack();
    Start();
    Transmit(0xA1);
    Ack();
    ReadData=Read8Bit();
    NoAck();
    Stop();
    int Start(void)
    SDA=1;
    SCL=1;
    for(a=0; a<10;a++);
    SDA=0;
    for(a=0; a<10;a++);
    SCL=0;
    return 0;
    void Stop(void)
    SDA=0;
    SCL=1;
    for(a=0; a<50;a++);
    SDA=1;
    for(a=0; a<50;a++);
    void Ack(void)
    TRISC |= 0x10;
    SCL=1;
    if(SDA)
    indic=1;
    else
    indic=0;
    SCL=0;
    TRISC &= 0xEF;
    void NoAck(void)
    SDA=1;
    SCL=1;
    for(a=0; a<10;a++);
    unsigned char i,rbyte=0;
    SDA=1;
    TRISC |= 0x10; //setting SDA as input mode
    for(i=1;i<=8;i++)
    SCL=1;
    rbyte<<=1;
    if(SDA)
    rbyte|=0x01;
    for(d=0;d<10;d++); //100
    SCL=0;
    TRISC &= 0xEF; //setting SDA back to output mode
    return(rbyte);
    AS_TEMP1 = var & 0x0F;
    AS_TEMP1=(AS_TEMP1>=0xa?AS_TEMP1+0x37:AS_TEMP1+0x30);
    AS_TEMP2=(var & 0xF0)>>4;
    AS_TEMP2=(AS_TEMP2>=0xa?AS_TEMP2+0x37:AS_TEMP2+0x30);
    hex_ascii(disp);
    delay(10);
    putcUSART(AS_TEMP2);
    delay(10);
    putcUSART(AS_TEMP1);
    delay(10);
    AS_TEMP2=AS_TEMP1=0;
    int i,j;
    for(i=0;i<itime;i++)
    for(j=0;j<2;j++);
  2. Militoy
    Militoy
    180
    Aug 24, 2010
    I’m not an expert programmer – and I haven’t taken time to look through your code (additional comments might make it easier) – but I2C functions typically employ a small delay routine in between SDA and SCL changes to give a clear sequence on the I2C bus – usually just a simple subroutine call and return as:
    Void i2c_dly (void) // i2c bus clear delay
    So a start bit sequence would look something like:
    Int Start (void)
    SDA = 1; // i2c start bit sequence
    i2c_dly() ;
    SCL = 1;
    For(a=0 ; a<10; a++);
    i2c_dly() ;
    SDA = 0;
    i2c_dly() ;
    SCL = 0;
    Return 0;
    If you’re having setup time errors you can try clearing the bus between changes – and see if your simulation improves. If not – nothing lost.
