What is power latch?
Discussion in 'Electronic Basics' started by [email protected], Jan 25, 2006.
  1. Guest
    Dear All,
    Product A "shall enable the power latch upon startup"?
    What is that mean?
    Best regards,
    Boki.
  2. Lord Garth
    Lord Garth Guest
    I'm supposing you are referring the tendency of the "A" series CMOS
    components (4000 series chips) to latch up when power is applied.
    This is due to a parasitic SCR inherent in its design. Looking through
    the layers, there would be a PNPN structure. If this latches on, there
    would be a destructive current flow causing the chip to self destruct.
  3. Jasen Betts
    Jasen Betts Guest
    Sounds like the device attached to the back if the on/off button :)
    Means they used google-translate or similar :)
    Bye.
    Jasen
  4. Pooh Bear
    Pooh Bear Guest
    As ever Boki, you manage to have trouble describing your problem.
    Now start at the beginning.......
    Graham
  5. Guest
    3.1 Startup
    3.1.1 Startup Power Latch
    A shall enable the power latch upon startup.
    3.1.2 Software Version
    Upon power-up, A shall write the software version to address 0x1234
    :) Any advice?
    Best regards,
    Boki.
  6. JeffM
    JeffM Guest
    If it is not clear from the document, then the document is incomplete.
    At a minimum, contact the individual who wrote the document;
    better yet, have him re-write it so that things are clear.
    Fuzzy specs benefit no one.
    This was my interpretation of the prose:
    Upon starting a Master Device, all slave devices are enabled.
    Example:
    http://groups.google.com/group/sci....ant-the-dust-colector-to-automaticaly-come-on
    I sounds like Jasen interpreted the sequence of events correctly:
    (Google-translate).
