What is modulator?
Discussion in 'Electronic Basics' started by boki, Sep 15, 2003.
  1. [/QUOTE]
    I don't believe you set me straight....... Hmmmm....Nope. In my
    humble opinion, you are not correct.[/QUOTE]
    And that opinion is demenstatable incorrect. I have given the
    mathematical outline as to why. Indeed, I have explained in detail why
    it is correct to state that the carrier amplitude varies an why it is
    also correct to state its the sidebands that varies. It is trivially
    obvious form the mathematical trigonometric identity relating products
    of sines with sums of differences of sines. To repeat, if one writes
    Vo = A(t).Sin(wt)
    There is no real rational argument that can prevent Sin(wt) being
    *defined* as the carrier, and A(t) *defined* as its amplitude. In
    addition, I agree, that there is no real rational argument that can
    prevent the alterative definition based on the "carrier" being constant.
    What part of "mathematical identity" do you have trouble with?
    This is a right daft arument.
    Unfortunately, this is a very constrained view of signal, or
    mathematical analysis. What part of "There is nothing unique in the the
    Time view or Fourier view" do you have problem with?
    Indeed, as soon as it is brought to explicit attention that the Fourier
    view is only one way of infinatly many ways to expand a function in an
    orthogonal set, it should be immediately clear that "The universe, is
    what we say it is" - James Burk - Connections" TV series.
    Kevin Aylward
    http://www.anasoft.co.uk
  2. Dbowey
    Dbowey Guest
    Kevin, If you are satisfied with your math modeled view of AM and it serves
    your needs then stick with it. As far as what is demonstrable, a math model
    "demonstrates" nothing. On the other hand, it is simple, with a frequency
    selective voltmeter or decent receiver, to demonstrate that the carrier
    amplitude is constant during AM modulation.
    Don
  3. I am satisfied with *any* number of math models that can be used to
    represent the real world. I am not stuck to just one model.
    You obviously missed the point. I have been discussing other, equally
    valid models such that their model parameters can be *physically*
    measured in just as valid a manner as, for example, the non unique model
    that uses sum and difference frequencies.
    Have a little think about what actually happens in this measurement.
    You still fail to see the point. This is *deeper* then what you suppose
    with such an elementary example. I don't know just what the problem is
    as to why you don't understand the point being made. Are you familiar
    with orthogonal expansions at all? You are making an assumption here
    that, in this case, that this *particular* definition and measurement of
    "carrier" amplitude is unique. It isn't.
    In your example here, if one decides to use equipment specifically
    designed to analyse a signal in the Fourier domain, that it will,
    necessarily, pick out the Fourier co-efficients. However, this does not
    mean that such measurement are any more real then, for example, using
    equipment that picks out the Walsh function co-efficients. (Walsh
    functions are an orthogonal set of square waves)
    Read my posts again, and pay particular attention to the notions of "non
    unique" and "equally valid physically"
    Kevin Aylward
  4. Bob Myers
    Bob Myers Guest
    More correctly, you should say that in standard AM
    (without a supressed carrier) there is a constant-amplitude
    component at the carrier frequency. That's not QUITE the
    same thing.
    Bob M.
  5. John Fields
    John Fields Guest
    Let me dumb this down a little so it's easier to visualize, OK?
    Using my previous example of a plate modulated linear final RF
    amplifier, let's use 1Hz as the modulating frequency and connect the RF
    amplifier's output to an oscilloscope (through an appropriate voltage
    divider, of course). I believe that what you'll see when the carrier is
    at 100% modulation is a 200VPP 1MHz signal when the amplitude of the
    modulating signal is at its positive peak and 0V when the modulating
    signal is at its lowest peak. Since the oscilloscope will be displaying
    time in the X dimension and voltage in the Y dimension, it should be
    readily apparent that the RF output signal's amplitude is varying in
    time but, even more important, that it is varying in step with the
    modulating signal. If you doubt that, then do this: Tune your
    voltmeter to 1MHz, modulate the carrier with a 1Hz signal and then
    report back as to how steady the voltmeter's needle (or display)
    remained during the test.
    As Kevin said, you need to think a little bit more about what's
    happening when you make your measurements.
  6. Dbowey
    Dbowey Guest
    Bob posted:
    same thing. >>
    Yes, but that isn't the form of AM being discussed. However, just to cover the
    bases........ And when suppressed Carrier is being utilized, even the low level
    carrier leak will have constant amplitude.
    Don
  7. Dbowey
    Dbowey Guest
    To dumb this down a bit, jfields posted:
    You have stated most of the obvious. Using a display in the time domain is an
    ideal method for determining percent modulaton. It's just displaying the
    algebraic sum of the voltages (carrier and sidebands). Good tool, but it
    doesn't help decide if the carrier is constant or varying. You are making an
    error in believing that it does.
    However, when you observe the carrier and sidebands selectively, you WILL
    observe that the carrier is indeed constant, and that is the point I am trying
    to make.
    When Kevin's math says one thing and observed facts show another, I believe one
    should rethink their model.
    Don
  8. Dbowey
    Dbowey Guest
    jfields also posted:
    << As Kevin said, you need to think a little bit more about what's
    happening when you make your measurements. >>
    I've thought about it quite a lot.. Turn the horizontal gain off and look at
    that nice vertical line pumpng up and down. It's just a voltmeter.... you
    think a bit more about that.
    Don
  9. Take a look at the carrier of WWVB at 60 KHz. It is modulated by a
    19 dB reduction in carrier level at a baud rate of 1. You can watch the
    carrier level change on a slow sweep across the scope tube. I wound a
    three foot square loop with 20 turns of 22 AWG wire, and used a couple
    caps to tune it to 60 KHz. A couple op amps gave me around 9 volts P-P,
    and you could watch the carrier level change.
  10. John Fields
    John Fields Guest
  11. John Fields
    John Fields Guest
    Try it with a 1Hz modulating signal and then think about why the line
    _does_ pump up and down. Hint: At modulation frequencies above a
    certain threshold, persistence of vision makes it impossible to follow
    the bouncing ball. But it does bounce, as you'll see if you let the
    beam play on a photodiode after your eyes fool you into thinking it's a
    constant amplitude.
  12. Jim Large
    Jim Large Guest
    Don,
    As long as you think that mathematics is invalid as a means
    to understand electronics, you're going to struggle to get
    anywhere beyond the "Gee golly Mr. Wizard, that sure is
    swell" level.
    You're right about one thing, math doesn't "prove" stuff.
    But PEOPLE prove stuff using mathematical arguments. Math
    is a language, invented by people so that they can have
    debates and discussions about how the universe works.
    Talk about carrier waves and modulation and signal
    processing on a mathematical level is interesting because it
    leads to new discoveries, new techniques. I'd love to hear
    about how your "frequency selective volt meter" works, and
    how to interpret its output, but c'm on! I want to hear
    about poles and zeroes or some equivalent explanation of how
    it processes the signal. Otherwise, without the math, I
    might just as well go downstairs and watch another episode
    of Dexter's Lab.
    -- Jim L.
  13. John Fields
    John Fields Guest
    The bouncing ball analogy isn't a good one.
    With the sweep off what will happen is that the carrier amplitude will
    be represented by what looks like a vertical line (but what is, in
    actuality, a spot on the screen oscillating vertically at the carrier
    frequency) with a length proportional to the amplitude of the carrier.
    The amplitude of the carrier will in turn be determined by the amplitude
    of the modulating signal, which will either add to or subtract from the
    CW length of the line. At high modulating frequencies the lengthening
    and shortening of the line will not be discernible because of
    persistence of vision, but at low modulating frequencies the length of
    the line will be seen to change as the amplitude of the modulating
    signal changes, and at a rate corresponding to the modulating frequency.
    Since the length of the line represents the amplitude of the carrier and
    it can be seen to vary as the amplitude of the modulating signal varies,
    the carrier amplitude does _not_ remain constant as it is being
    modulated.
  14. Dbowey
    Dbowey Guest
    Jim Large posted, in part:
    "I'd love to hear about how your "frequency selective volt meter" works...."
    Google will offer up 2980 links for that. Have fun.
    Don
  15. Dbowey
    Dbowey Guest
    jfields posted:
    << On 19 Sep 2003 19:56:15 GMT, (Dbowey) wrote:
    [/QUOTE][/QUOTE]
    What is there to experiment about? The measurement of the carrier separate
    from the measurement of a sideband generated by a modulating tone (1000 or 1004
    Hz), was a common set of tests on analog transmission systems.
    Don
  16. I'll expand on this. In fact, it is not a simple matter to show that the
    carrier
    is constant or varies. Indeed, its not possible, in principle.
    To determine that one is measuring the carrier frequency, rather than
    its side
    bands, one necessarily requires a small BW filter. However, a narrow
    filter will
    automatically filter out changes in signal level, even if they were
    there, that
    is the measurement itself, forces the carrier to be appear constant. If
    the
    carrier was changing at a 10Hz rate, it would not get through a 1Hz
    filter.
    However, if the BW is increased, then you don't know what frequency the
    carrier
    is, so you cant say much about it. It could be any value within that BW.
    This
    means that the so called sidebands could be measured as the carrier and
    subsequently show variations in the carriers amplitude. This is
    expressed in a
    fundamental mathematical, provable, relation between F and T:
    sigma_f.sigma_t >=1/2
    That is, the product of the standard deviation of f(t) and the product
    of the
    standard deviation of its fourier transformis always greater then 1/2.
    This
    results shows that it is impossible, inprinciple, to know both the time
    and
    frequency distribution together to an
    arbitrarily degree of accuracy.
    Since the carrier amplitude has to vary at the modulating frequency, and
    any
    supposed sidebands are at this distance away from the carrier, its not
    possible
    to have a BW that allows possible carrier amplitudes to be measured, and
    simultaneously determine that you are actually measuring the carrier
    frequency.
    To expand on this a bit more. One has to define what is referring to
    when one
    says things like "constant carrier amplitude". One needs to distinguish
    between
    averages, peaks, instantaneous etc. Just exactly what is being declared
    constant? If one modulates a carrier with a fixed amplitude sine wave,
    and does
    a frequency sweep, with low BW, i.e. say, 1Hz resolution. Certain
    amplitudes of
    "sidebands" and "carrier" will be measured. If the modulation amplitude
    is
    increased, the "sidebands" will increase, and the "carrier" amplitude
    will
    remain invariant. So, in this average sense one might claims that the
    carrier
    amplitude remains constant. However, this is only achieved because the
    BP filter
    removes any potential "instantaneous" variations from the outset.
    Kevin Aylward
  17. John Fields
    John Fields Guest
    [/QUOTE]
    Hz), was a common set of tests on analog transmission systems.[/QUOTE]
    Yes, of course, but what was being measured was the average amplitude of
    the carrier. By using a slowly varying modulating signal the amplitude
    variations of the carrier caused by the amplitude variations of the
    modulating signal can easily be seen.
    As a matter of fact, changing the DC plate voltage of the final will
    cause the RF output to change, proving that amplitude modulation _does_
    cause the carrier amplitude to change.
  18. John Fields
    John Fields Guest
    Beg to differ!^) If you use DC as the modulating signal it's not only
    possible, it's extremely easy. For example:
    ACIN---------------+
    VMOD>-----+ |
    [LED]--> [LDR]
    | +----->ACOUT
    | [R]
    GND>------+--------+
    This way it's only neccessary to change VMOD in order to cause the
    amplitude of ACOUT to change, eliminating the problem of the pesky
    sidebands interfering with the measurement. (As long as you wait long
    enough after changing VMOD. ;^) For AC modulation:
    VMOD--[C]-+ |
    VBIAS-[R]-+ |
    [LED]--> [LDR]
    | +----->ACOUT
    | [R]
    Certainly nothing elegant or linear about either circuit, just brute
    force proof of principle.
  19. Not wise John:)
    You can't. If it is dc the carrier will *never* change. You can't just
    ignore this inherent fact. This is the real world. It is ruled by the
    laws of physics.
    Nope:)
    You obviously did not take in the sigma_f.sigma_t >=1/2. Its a
    fundamental result. Not open to debate.
    What you are now about to do, is use all those old arguments attempting
    to show that one can determine position and momentum together. You will
    fail. Trust me on this. Look up QM, e.g. wave-particle duality aspects.
    For example:
    Yep. Same old arguments.
    Oh?. What happens to the carrier frequency while VMOD changes in time?
    Nope. As soon as you start changing vmod, the frequency because
    uncertain. You don't know that it is at the carrier frequency any more.
    You have to measure it. To measure frequency necessarily takes a finite
    tine, as noted in the Time-Frequency relation.
    You have to wait *for ever* before the carrier frequency can be shown to
    the same as its original value. Therefore, you cant claim that you are
    measuring the carrier, because you can't prove what its actual frequency
    is with a finite wait time. The Time-frequency uncertainty relation will
    bite you. There is no way around it.
    For AC modulation:
    Nope. *The* principle is that it is absolutely, theoretically and in
    principle to simultaneously know a signals frequency spectrum and time
    spectrum to an arbitrary degree of accuracy. Indeed, QM is just the
    observation that position and momentum are related by Frequency-Time
    fourier transform pairs as noted above.
    Kevin Aylward
  20. John Fields
    John Fields Guest
    Well, it remains the same, of course, but the sidebands are created when
    VMOD is changing.
    Yes, of course, but that's not the point. The point is that the carrier
    _amplitude_ changes during modulation. Using DC as the modulating
    source allows carrier amplitude measurements to be made with different
    _static_ values of modulating signal, eliminating the effects of the
    sideband "interference".
    I see you saw the smiley but, again, I wasn't talking about frequency, I
    was talking about amplitude. Check abse for some photos showing
    ACOUT (f)VMODdc in about a half an hour.
