What is making a squealing noise on this plug in?
Discussion in 'General Electronics Discussion' started by Robmac, Nov 12, 2017.
  1. Robmac
    Robmac
    Nov 12, 2017
    Hi there,
    I have a Christmas village decoration and the plug in box makes a high pitched squealing in time with the lights whenever it is switched on... am I able to remove a piece to stop it? If so, which piece?
  2. Minder
    Minder
    3,076
    657
    Apr 24, 2015
    It does not look like a SMPS so I would guess the transformer is vibrating due to the load.
    You could try taking the yellow tape off and spray or brush shellac on it.
    If you place a finger on the top of it can you feel any vibrations?
    M..
  3. duke37
    duke37
    5,364
    771
    Jan 9, 2011
    It may be a SMPS with Q1 as the switching transistor.
    If D1 to D4 form a bridge rectifier connected to the mains, then it is a SMPS.
    Is it my imagination that the electrolytic capacitors have domed tops? Faulty caps could overload the transformer.
    davenn likes this.
  4. davenn
    davenn Moderator
    13,812
    1,945
    yes it does look like one ;)
    As Duke said, the transistor gives it away :)
    guaranteed to be a switching chip and some other SMD components on the bottom side of the board
    and yes, that is still the logical conclusion
    but note he said it's squealing
    SMPS transformers squeal, linear transformers buzz/vibrate
  5. Robmac
    Robmac
    Nov 12, 2017
    Update: I covered the transformer in shellac and it minimised the squealing enough to make it inaudible unless you are right next to it.
    That should work for now haha.
    Thanks all!
    davenn and Minder like this.
  6. Minder
    Minder
    3,076
    657
    Apr 24, 2015
    Your welcome.
    Check to see if the transformer is made up of steel laminations, if so it is a linear supply, also the primary connections appear to be fed right off the AC.
    M.
  7. davenn
    davenn Moderator
    13,812
    1,945
    ohhhh golly gosh
    think you need some new glasses ;) ..... don't you see the 4 rectifier diodes beside the AC input pins
