What is Continuous Audio?
Discussion in 'Electronic Basics' started by [email protected], Aug 22, 2006.
  1. Guest
  2. PeteS
    PeteS Guest
    It means you can run 15W of audio into it continuously (when part of a
    circuit, obviously). That 15W should be RMS, I expect
    Some of the audio will get absorbed by the device, the rest will go to
    the speaker.
    Cheers
    PeteS
  3. BobG
    BobG Guest
    It means the rheostat can dissapate 15 watts. You can get into an
    argument about whether this is RMS volts across a pure resistance, or
    average power, or 'music power' or 'peak power' or several other
    confusing ways of making an amplifier have more power.
  4. Guest
    Thanks...
    Another unrelated question to this one, so in the same spec, Insulation
    Resistance means the resistance of the insulation?
  5. Eeyore
    Eeyore Guest
    It does indeed.
