What is 'Alt' parameter in grid setting window of eaglecad?
chrisjrollin
May 3, 2015
5
May 3, 2015
5
Hello to all,
Could anyone please tell me, what is the 'alt' parameter in the grid setting window and what it is used for?
Thank you.
Harald Kapp
13,700
13,700
Eagle allows you to define two grids: a standard and an alternative grid. You'd typically work with the default grid. However, if you need to work out fine detail, you may want to use a finer grid. By pressing the ALT key the alternative grid is activated (from the eagle help file).
