What is a good way to compare register values in a PIC assembly
Discussion in 'Microcontrollers, Programming and IoT' started by Dwnld_pwm, Apr 10, 2019.
  1. Dwnld_pwm
    Dwnld_pwm
    Apr 9, 2019
    Hello everyone.
    I'm using a PIC16F887 with the PICkit2.
    There doesn't seem to be a compare instruction so I'm wondering how one would go about comparing the values of two registers.
    For example let's say Register REG1 has a value b'00100010' and REG2 has b'000000000' but the value of REG2 increases by 1 every loop iteration. I want the loop to stop when REG2 = REG1.
    Is there a way of comparing them?
    It's easy in C, but how do I implement it in assembly?
    I'll leave a mixture of Assembly and C for reference.
    Cheers,
    MOVLW b'00100010'
    MOVWF REG1
    CLRF REG2
    Loop:
    INCF REG2
    ;(if REG2 == REG1){
    goto stop
    else{
    goto Loop
  2. Dwnld_pwm
    Dwnld_pwm
    Apr 9, 2019
    Think I've just figured it out, here's the solution for whoever stumbles upon this in the future
    MOVLW b'00100010'
    MOVWF REG1
    CLRF REG2
    Loop:
    INCF REG2, F
    MOVFW REG2
    SUBWF REG1, W
    BTFSS STATUS, Z ;If REG1 = REG2 then REG1 - REG2 = 0 setting Z = 1
    goto Loop
    goto Stop
  3. Minder
    Minder
    2,948
    623
    Apr 24, 2015
    Also the logic instructions can be used in different ways to compare. notably the AND, XOR AND IOR.
    M.
