Hi
Newbie here!-)
So, to give some background on what I'm trying to achieve...
I am looking to add a fifth channel to the transmitter for my RC plane. The receiver I have is 6 channel and the transmitter currently has 4 channels set up. There is provisioning for a fifth channel, although upon closer inspection it seems like there's a resistor (or something... I'll call it a resistor/component for conversion sake) which has not been installed.
Noting that the one difference with the 5fth channel from the others is that it's basically an on/off type switch rather than the analogue modular type of the other channels. This is where I'm not sure if it'll be the same type of resistor/component which should be fitted here. Also the physical space for the fifth channel's resistor/component is bigger than the others (although this may simply be for after-market fitting?)
Please see below picture which shows what I’m talking about:
https://plus.google.com/photos/1091...1845278897?banner=pwa&authkey=CNDZyJvIgoPJ9AE
You should be able to see the blank space (labelled C5) and the other (C1-4) channels which have resistor/components fitted.
Please let me know if there’s some more info which will be useful to help find out what should go here. The make of the transmitter is Art-Tech and I can’t seem to find and PC board diagram.
Thanks in advance for any help available!
/Andrew
Newbie here!-)
/Andrew
